Limited slip differential options
Hey guys.
Just trying to get a post (sticky?) that has all options for LSD in it. I'm not an expert, so will need help. Part numbers would be great -Kaaz clutch type 1,1.5,2 way. -Cusco clutch type -OS Giken clutch type -Quaife helical -TRD helical(obsolete but used available.) -OE helical from JDM (I don't know anything about these. Same as TRD? Which vehicle have them?) -OBX helical (do they even make one for the Yaris?) Not going to include Phantom Grip as they are not proper LSD. Any additions (companies, part numbers, options, required fluids) and corrections would be great. Thanks. Cory Just going to add a tag for "torsen" in case someone is searching. |
2ZR swap. DO IT! Ask how!
There's a few options for Quaife, based on which gearbox/engine you have:
1.5 L 1NZ-FE > QDF15E 1.8 L 2ZR-FE > QDF21E Both of these units are 8-bolt, but the 21E uses the larger output shafts of the 1.8 L model, and has a different shoulder diameter for the front ring gear. If you have a 1.5 L, you need the 15E. |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I'am running the Kaaz and... I love it! Don't know why I waited so long to buy it
I Drive a 129whp Yaris ;) |
#4 | |
![]() Drives: Yaris Sedan YRS Join Date: Mar 2013
If the LSD for a 1nz-fe would still be able to fit on a 2nz-fe or will I need some modification's, if so how or is it possible?
I believe that your 2NZ-FE Yaris over there is paired with the C54 transmission. If that is the case, then you require a different LSD than what is used with the C50 for the 1NZ-FE.
| WTB: Limited Slip Differential | FHT_Racing | Willing to Buy by private party | 0 | 10-10-2014 04:23 PM |
| KAAZ Limited Slip Differential Compatibility | sheekeebut | Performance Modifications | 11 | 07-24-2014 11:18 PM |
| fog light options | charleschia1986 | Cosmetic Modifications (Exterior/Interior) | 3 | 11-13-2009 04:00 PM |
| TRD limited slip: part number? | cali yaris | Performance Modifications | 9 | 08-13-2009 01:29 AM |
| Limited Slip | regal | Performance Modifications | 13 | 03-20-2009 09:16 PM |
