Old 03-13-2009, 12:03 AM   #1
regal
Limited Slip
Is there any way to change to a limited slip differential with a Yaris 5 spd ?
Old 03-13-2009, 12:04 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yes. www.microimageonline.com sells LSDs.
Old 03-13-2009, 12:46 AM   #3
There is TRD, which you must import (expensive side) and KAAZ, which I run in my car (less expensive side). I am very happy with the one in my car.
Old 03-14-2009, 09:20 PM   #4
revoturbo
revoturbo's Avatar
Drives: yaris
Whats difference LSd 1 way & 1,5 way?
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 03-14-2009, 09:37 PM   #5
1-way only works during acceleration, 1.5 way works also with deceleration.
I THINK.
Old 03-14-2009, 11:09 PM   #6
ddongbap
It only works half in deceleration. Hence 1.5.
Old 03-20-2009, 01:29 AM   #7
regal
I know on my chevy pickup the posi rear is a life saver in the snow.
Would it be a safe bet that the TRD LSD for the Yaris would be a big advantage in the snow ?
Old 03-20-2009, 01:40 AM   #8
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
It would be, but being a FWD car, the Yaris should get around okay in the snow, anyway. Good snow tires would probably be a better investment. Without them, even with an LSD... you'd just be spinning two tires instead of one. (which is arguably more dangerous as you'll lose ALL directional control)
Old 03-20-2009, 02:51 AM   #9
dallas
Drives: Yaris Hatch /Landrover D2
Limited slip on the front wheels on ice and snow can be scary with tons of understeer, and plowing, I hated it. For not loosing speed at an autocross when one wheel lifts and the other wheel losses power, get the limited slip, if its for winter driving as mentioned above get good winter tires.
dallas is offline   Reply With Quote
Old 03-20-2009, 03:09 PM   #10
silver_echo
ekodrvr
silver_echo's Avatar
what type of LSD is it?... cone clutch, ramp type, viscous type, quaife?
i like this smiley...
silver_echo is offline   Reply With Quote
Old 03-20-2009, 04:23 PM   #11
regal
trd
Old 03-20-2009, 05:50 PM   #12
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Just make sure that when you change the diff that you purchase a new speedometer gear before you install the new diff . In case that you break the old one when removing it . Its cheap and could be a hell of a time saver . That is assuming that the Yaris speedo gear is made from plastic
Old 03-20-2009, 06:26 PM   #13
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
check the classifieds, someone is selling a TRD one for around $650 i think and you can sometimes catch them on ebay for cheap money. Also remember the AE101 differentials fit as well. But if you do need one that is not used, i would recommend MicroImage all the way. Make sure you research the type you want, being helical,clutch,etc
Old 03-20-2009, 09:16 PM   #14
kngrsll
Apexing Egg!!
kngrsll's Avatar
lol thanks, thats me
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
NST End of Jan Sale ... Very limited quantities NonStopTuning NonStopTuning 14 02-03-2009 09:50 PM
NST Thanksgiving Weekend Sale ... Very Limited Quantities NonStopTuning NonStopTuning 16 12-03-2008 06:29 PM
Superman Limited Edition Yaris St.Francis General Yaris / Vitz Discussion 6 10-13-2006 08:50 AM
Detailed dealer pricing on the new, 2007 Toyota Yaris. tomjasz New YARIS Purchase Forum 3 08-11-2006 10:46 PM
