![]() Drives: 2007 Yaris 4 Dr HB LE Auto Join Date: Jan 2015
How to adjust clock in radio
Hi everybody ! I got a 07 Yaris LE I like to know how can I adjust the clock located in radio, because the owner's manual doesn't mention it. Thanks in advance.
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Post a pic of it please.
Top right of the page gives us a Search option on this forum. Here's a link on how to change the time.
http://www.yarisworld.com/forums/sho...=setting+clock |
This is the radio/CD player I have.
Going to make a guess here but hold the number 3 SET button down until the number blinks (most likely starting the hour) then tab until the desired hour is reached, then hit the SET button which will most likely start the blinking of the minutes. And repeat functions as you did for the hour. Again, it's a complete guess but sounds plausible, who knows?
I would say hold 3. And press 1 or 2 to adjust the hour and minutes.
I don't understand the Yaris coming with this radio in Canada. Stupid dealer installed radios... |
I knew it couldn't have been this setup, because that would have been too obvious even to the most inexperienced driver.
My friend also has the CD player above with the clock.
Must be a Canadian thing.
Mine looked originally like this: ![]() Until I changed it to this:
#10 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Unfortunately the ones buying the lower trims enjoy the simplicity of things, and are not selling them off. Even i had to buy an aftermarket radio panel as the OEM ones were more expensive and was only available at the stealership, much less didnt include the spacers. |
I used the spacer panels initially, but that looked too ghetto for my taste.
Senior Veteran
Drives: 2007 5 door hatchback Join Date: Jan 2015
hi KAR98. do you like call of duty by any chance? :)
OP and future readers of this thread, for setting the clock, it's done by pressing and holding the AM/FM button at the top right (you can see that it says "clock" just above the button). while holding that button down, press the "1" key for setting hour and the "2" key for minute. |
Hi ! I found a solution it's so simple just press "AM-FM" button for 2 sec. it will disable.
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Custron T1062TYT Review (Long) | mr.steevo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 11-24-2011 02:13 PM |
| ATL, I want to trade my Upgraded built in radio... | matthewallanstill | Southeast | 2 | 03-28-2009 06:29 PM |
| Mounting a CB radio somewhere | Sodium Duck | Cosmetic Modifications (Exterior/Interior) | 1 | 03-06-2009 01:50 AM |
| I want to trade my Upgraded built in radio... | matthewallanstill | Items for Sale by private party | 0 | 09-03-2007 09:50 AM |
