Old 03-05-2015, 07:43 PM   #1
yaris0985
Drives: yaris sedan 09
How to fix p2138-yaris
I have code this code 1-2x Time winter....
After looking fews post yarisworld i not sure about the problem
Tps/ tb / pedal sensor.....
I have Only 1code p2138
Start with change the pedal sensor+cleaning the tb ???
An suggestion
Yaris 2008 automatic 1nf-ze
Thank
yaris0985 is offline   Reply With Quote
Old 03-05-2015, 08:40 PM   #2
P2138 is specifically for the pedal circuit, so cleaning the throttle body will not help. Besides the pedal, the ECM could also be the culprit. I would check the ECM connectors for corrosion, but more likely the issue is with the pedal.
Old 03-06-2015, 09:45 AM   #3
yaris0985
Thank Ctscott
The choice now is pedal sensor or the pedal
What do you suggest
Old 03-06-2015, 01:39 PM   #4
The pedal sensor is part of the pedal assembly.
Old 03-06-2015, 05:26 PM   #5
yaris0985
Thank my mecanic Guy remove a antitheft wich was plug directly on the pedal the throttle answer a 100x Times better but now i lose the Cruise control....(rostra)
I return monday to see him to get this fix....i hope
Old 03-06-2015, 09:45 PM   #6
Ah - The Rostra cruise control systems were recalled in Canada and you are not the first to have one fail where it effects the throttle position sensor data.
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
