Old 03-14-2015, 03:37 PM   #37
dieselphreak
Drives: 2009 yaris
update: New pcm, still same results. I'm at a total loss here.
dieselphreak is offline   Reply With Quote
Old 03-14-2015, 04:19 PM   #38
Your wasting time and money now. Time to get it hauled to a shop.
Old 03-14-2015, 05:43 PM   #39
Originally Posted by dieselphreak View Post
Ok I'm still ready to condemn the ecu. However, let me clarify a few things.
The back seat is out of the car and I have wired up an LED to monitor pump operation. Nothing with key on, only while cranking or running on starting fluid
The new issue I noticed is AFTER you try to start the car and give up, there is a high pitched noise coming from the throttle body that only quits when you either unplug the throttle body or cycle the key. The battery isn't low either as I have been keeping a charger on it.
Also, my final question, since this car does NOT have the immobilizer, if I get a used ecu that came out of a 09 automatic with no immobilizer does it still need to be programmed?
Not really. The only reason to reprogram it is if your state does OBD emissions, where they plug into the car and expect it to respond with its proper VIN.
Old 03-15-2015, 12:42 AM   #40
dieselphreak
Drives: 2009 yaris
ok, mild update,
i just ASSumed since the new pçm, that the injectors were not firing since it would still run off of starting fluid, however,
i have spark and injector pulse with the new pcm, just the fuel pump doesn't run,
old pcm the fuel pump runs, no injector pulse... *&$@$&*
Old 03-15-2015, 08:29 AM   #41
ok, mild update,
What's the ten digit (5-5) part number on the new one?
Old 03-15-2015, 10:53 PM   #42
dieselphreak
Drives: 2009 yaris
ok, not sure what the deal was or what happened. but i went out there a few hours ago and tried it, it started, been running fine ever since. tried the old pcm just to see, no injector pulse, new pcm it runs. not sure but i'm damn sure happy! lol
Thanks everyone for your help!
Old 03-15-2015, 10:54 PM   #43
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 03-15-2015, 11:03 PM   #44
If everything remains OK, I'd love to get my hands on the bad one to see what failed within it.
Old 03-15-2015, 11:51 PM   #45
JEducate
Drives: 2009 5dr S series
I need help too! Mostly with the gas gauge.
Over the winter, my car's gas gauge was going back and forth to one bar to two bars left. It ended up stalling. Then, about a month ago, it said there was two bars left, and it stalled. I was hoping that it would be just frozen pipes. We have had a few warm days. I had to fill up my tank because it was stuck on three bars from the bottom. It will show it being filled up, but will stop at the third line. I read that it could be the indicators could be dirty. Any suggestions? Can I fix it myself, or do I have to go to a mechanic?
JEducate is offline   Reply With Quote
Old 03-16-2015, 06:51 AM   #46
That would be a a bit if a threadjack, as your post is completely unrelated to that of the O.P. Typically when a gas gauge does that it is due to the resistive strip for the fuel level sender either being dirty or being worn. You can try adding fuel system cleaner to the tank, but if that doesn't help, then you are looking at having to have the sender removed and replaced.
Old 03-16-2015, 11:29 AM   #47
JEducate
I know this was not related to the O.P. This is my first time on here and did not know how to do a new thread. Thanks for helping.
Old 03-16-2015, 11:36 AM   #48
bronsin
bronsin's Avatar
Welcome to the forum, an excellent place to learn about your Yaris!
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 03:18 PM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 06:12 AM
Yaris and Viper 4204v remote start eeosman In Car Entertainment + Electronics (audio / video / alarm) 19 12-08-2013 02:49 PM
