Old 02-06-2013, 10:49 AM   #1
volks_r_us
Drives: Toyota Yaris 2008 CE
Hard start in the morning 2008 Yaris CE
Hi
This is my first Toyota and I already have a problem
It's a 4 doors 2008 Toyota Yaris CE VVTI 1.5L automatic with 56K miles.
It's cold here below freezing point. Everymorning my car is hard to start.
I engine crank normally but I have to crank for like 10 sec on order to get it start.
I replaced the spark plugs and air filter without any improvement.
I checked with a scaner for fault code, Nothing.
Once it have started everything fine, it will start right away if you turn it off and back on, until the next day.
Basically the problem is only the first cold start of the day.
Anybody has an Idea what to check ?
volks_r_us is offline   Reply With Quote
Old 02-06-2013, 10:52 AM   #2
If it cranks over fine (i.e. the battery is not low, where the starter is barely turning the engine over), then my guess would be a fuel system issue. It sounds like the fuel system is depressurizing overnight.
Old 02-06-2013, 10:59 AM   #3
volks_r_us
Yeah that was my guess, is this a common issue on this car ?
I have to replace the fuel pump ?
Old 02-06-2013, 11:32 AM   #4
I don't think it is common, but one or two one here have mentioned a similar issue. You would really need to do some troubleshooting with measuring fuel pressure to determine if the fuel pump needed to be replaced.
It could also be that the fuel filter is plugged enough to make starting difficult. That is only a $37 part, but is located within the tank.
Old 02-07-2013, 03:17 PM   #5
Vinceb
Drives: 2008 5 Speed Sedan
I thought the car would throw a MIL code if the fuel system looses pressure?? Mine has never had an issue like that, -22c last night, started right away this morning, 204,000km
Vinceb is offline   Reply With Quote
Old 02-07-2013, 03:26 PM   #6
Only if the evaporative system looses pressure during the over-night test will it throw a code (which is actually completely separate). There is no pressure sensor between the fuel pump and the injectors.
Old 02-08-2013, 12:32 PM   #7
volks_r_us
I checked the fuel pressure and residial fuel pressure. It's fine
Old 02-08-2013, 01:11 PM   #8
OK - So you've done the plugs and checked the fuel pressure. The remaining things that I can think of are the coils (although if one or more were having issues I would think it would run horribly once started), and the fuel filter.
Old 03-09-2018, 03:18 PM   #9
Kousi
Drives: Toyota yaris
Did u find the problem
Kousi is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
2008 Yaris Sport For Sale 2008er Items for Sale by private party 5 04-22-2009 10:02 AM
