Old 07-31-2015, 04:03 PM   #1
djhuddy2442
djhuddy2442's Avatar
Drives: 2008 toyota yaris hatchback
Megasquirt ECU
Well tomorrow is the big Day. The megasquirt goes into the car for a ful stand alone ECU I feel like a giddy little school girl. I will post pics and results later next week while on vacation.
djhuddy2442 is offline   Reply With Quote
Old 07-31-2015, 04:06 PM   #2
Jason@SportsCar
Nice. I assume you are converting to a drive by cable throttle body?
Old 07-31-2015, 04:20 PM   #3
KTS
KTS's Avatar
Drives: Vitz RS
Good luck with the install and tune. Keep us updated. I am currently having a difficult time with an AEM EMS-4 standalone.
KTS is offline   Reply With Quote
Old 07-31-2015, 04:21 PM   #4
djhuddy2442
i am and i will
Old 08-01-2015, 06:31 PM   #5
Yapyzzer
Drives: 2004 Echo 3rd
Subscribed:) Good luck with install!
Yapyzzer is offline   Reply With Quote
Old 08-01-2015, 06:48 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I've found that a throttle controller opens up the DBW throttle mighty quick... I'm not sure it would make a huge difference in the end over DBC, but of course there's only one way to find out... I've been thinking about doing this mod if I ever get my nitrous tank installed...
Old 08-03-2015, 02:13 PM   #7
djhuddy2442
heres a question i have been throwing through my head.
Would a toyota corolla air intakemanifold and throttle body fit on the the yaris motor?
Old 08-03-2015, 03:45 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Not directly. The 1.8 L engine's pistons are father apart, and the throttle body inner diameter is large enough to allow the gasket to fall into the plenum.
Sent from my XT1031 using Tapatalk
Old 08-03-2015, 06:19 PM   #9
Rigaud
Drives: 2009 Yaris
Yes they can be fitted the aluminum version from older Corrola or Celica's. Spacing is excellent, bolts holes no. You need to have a flange machined, also a 4 bolt to 3 bolt TB adapter or cut the plenum and weld the new mounting plate. TB from a 1ZZ fits, do a search and you'll find all the info you need. Also Tooter had intakes modified but I don't think he does anymore. Maybe he'll chime in.
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
MegaSquirt ecu monchyxb Forced Induction Forum 14 03-31-2012 10:59 AM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
