Old 03-08-2011, 10:51 PM   #1
monchyxb
Drives: scion xb
MegaSquirt ecu
I just bought a megasquirt ecu and I'm planning to install it myself and was wondering if somebody had installed it in a 1nz-fe so maybe can give me a little help because I know how to install everything except the ignition and the megasquirt only has one cable for that and that's what I need to find out.
Any help will be appreciated!
monchyxb is offline   Reply With Quote
Old 03-08-2011, 11:13 PM   #2
It says you drive a Scion xB? That would be a different pinout than a Yaris, right?
Old 03-09-2011, 02:45 AM   #3
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
please clarify.. is it one cable with four wires or just one wire for ignition output??
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 03-09-2011, 08:01 AM   #4
monchyxb
Drives: scion xb
Yes, its a different pinout. And yes its one wire for ignition output. I was reading and a possible solution can be modifying the ecu to have 2 cables for ignition and then using a term called wasted spark :/ no idea what that is but I'll keep reading and let you guys know!
Old 03-09-2011, 11:25 PM   #5
scioncrew
scioncrew's Avatar
Drives: SCION tC
i would send that unit back and get one with 4 ignition out puts. you will be better off.
Old 05-23-2011, 08:30 AM   #6
LittleRed
LittleRed
Drives: 2008 Yaris Hatchback 5spd
Maf sensor
Do u know where i can get a high-performance MAF.... like JET ...or another reputable brand... Ive cleaned it with MAF cleaner a couple of times... but still comes up with MAF code... and i had re-set it each time...
LittleRed is offline   Reply With Quote
Old 06-15-2011, 06:53 AM   #7
riverc4c
Drives: 2010 Yaris Sedan Silver
What version MS do you have? I have V.3 and it accepts the stock crank signal. If you don't want to tinker with it too much, you can always go with an EDIS ignition setup that works easily with the MS. If you do this though, you have to install a 36-1 Trigger wheel and another VR sensor. With the stock setup, just jumper accordingly, feed the signal (1 Wire) to the MS ECU and it will control the 4 COPs.
riverc4c is offline   Reply With Quote
Old 06-15-2011, 11:31 AM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
already an interesting thread
Old 07-05-2011, 10:58 PM   #9
Pur_Blu
Pur_Blu's Avatar
Drives: NCVC craziest
Send a message via AIM to Pur_Blu Send a message via Yahoo to Pur_Blu
Any updates on this setup?? I wanted to go megasquirt do to price and expansion options.
Pur_Blu is offline   Reply With Quote
Old 07-06-2011, 03:22 PM   #10
metalshark
MetalShark
Drives: 2008 Yaris LB
wasted spark means the plug fires every revolution. The "wasted" spark fires during the exhaust stroke.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 03-06-2012, 09:12 AM   #11
misbah608
Drives: toyota yaris 1nz-fe
I have got toyota yaris 1NZ-FE, can any body let me know how to mega squirt it?? i 've already purchased the kit, now trying to install it... need your help and suggestions and help..
misbah608 is offline   Reply With Quote
Old 03-06-2012, 09:54 AM   #12
Do you have a more specific question? How about some pictures of your progress?
Old 03-08-2012, 04:23 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Did you install an aftermarket intake system?
Some have been known to cause CEL codes do to improper intake volume. Just a thought.
Old 03-28-2012, 07:28 PM   #14
byar12
Drives: Yatis
This will be a lot of work. Good luck with this. I have a MS2 sitting here for another project and am not willing to put the time into turning the Yaris into stand alone EFI. You will end up spending a lot of money just installing a mechanical throttle body. I'm also not sure if they TDI is logic driven or just dummy coils. I think its logic since they have 4 wires. Anyhow, I wondered about doing this, but it's not worth the trouble. There are better options.
byar12 is offline   Reply With Quote
Old 03-31-2012, 10:59 AM   #15
OP = MIA
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Yaris has a learning ecu? YogiYaris Performance Modifications 9 05-30-2007 07:03 PM
