![]() Drives: 2007 Yaris Join Date: Aug 2015
Downshifting grinding
I just got a 2007 manual tranny yaris and it doesn't want to shift into 2nd unless I'm going below 25mph does a little grind. down shifts fine below that speed. Is this normal? going UP thru the gears no issues what so ever!
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
My transmission was doing the same thing... It was the synchronizer that was worn.
that's what I was thinking how much was it to fix ?
I fixed mine with $350 because I bought an used Scion xB transmission and swapped the input, countershaft and differential to my transmission because the xB has a 4.31 final drive. I also did the whole job myself so no mechanic fees.
| Grinding Noise While Turning | 09heavychevy | DIY / Maintenance / Service | 17 | 04-22-2025 07:21 AM |
| Grinding noise when turning sharp right | roblobstuhh | DIY / Maintenance / Service | 14 | 07-08-2015 09:28 AM |
| Grinding noise in reverse | NickNickNick | DIY / Maintenance / Service | 14 | 03-15-2013 03:10 AM |
| ABS?, Grinding Noise When Brakes Are Locked!??? | p0pNfr3sh | DIY / Maintenance / Service | 3 | 03-03-2010 05:22 AM |
| Grinding sound from engine area | Thsplayer | DIY / Maintenance / Service | 0 | 01-03-2010 05:09 AM |
