#1 |
![]() Drives: 2009 Toyota Yaris 5dr Join Date: Jun 2013
Grinding noise when turning sharp right
I accidentally ran over a raccoon the other night (I felt absolutely terrible) and about 20 mins later when I finally got home and was making a sharp right to my driveway, my car started making a grinding noise. I localized the noise and it came from my left front wheel. I'm absolutely dumb when it comes to cars since I just got this hand-me-down and now I am paranoid. What is causing the grinding noise? Even I hurt when I hear it. It happens even without the brakes applied and intensifies as I accelerate while making the sharp right turn. I'm really worried as to how serious this is. Thoughts? Thanks in advance.
#2 | |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
You may have to reattach or cable tie them back. They are very flimsy and easy to mess up. Easy fix. |
#3 |
Drives: ford150 Join Date: Jan 2014
This type of a noise is usually produced by a faulty power steering pump or transmission. Mostly, it could be like a noise on the transmission itself. It would be nice if you flush the transmission.
#4 |
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Yea sounds like a cowling has come away and is rubbing with the tyres
#5 |
ThatYarisGuy
Drives: Toyota Yaris 2012 SE Join Date: Oct 2012
the ghost of the raccoon is haunting your car
#6 | |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
I'm guessing it's the cowling as well.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#7 |
Or the brake dust shield.
#8 |
Sounds like it must be slow in the shop ..lol lets not forgot new brakes tires etc hehe
#9 | |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Electric steering on US Yaris .The OP said it started after striking the animal , it's not the tranny....geeeeeeez . Probably the plastic wheel-well as mentioned above . |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I second what Scott said, likely the dust shield/brake backing plate
#11 |
![]() Drives: 2008 Yaris Join Date: Jan 2014
Hit a big one myself doing 60mph in the dark one morning. Hit so hard in the front it broke some of the bodywork down low and even bent my radiator support slightly. It also did a number on the front cowling which may be what is making the noise you have. I had to wire mine back up. Looked for the carcass on my way home from work later that day. Nothing to be found, maybe he thought I was just a big insect. These cars are actually pretty durable. I hit a huge road gator (chunk of trucker tire about 2 feet long ) underneath mine on the interstate doing 75mph. Made a hell of a racket and scratched some undercoating but that was about it.
#12 | |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
griding noise
#13 |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
My vote as the noise is grinding not scraping is you ruptured the CV boot and have lost most of the grease in the CV joint. If so in needs immediate attention.
#14 |
found the problem
found out what it was........the blower motor is scrapping the filter when I turn left. weird no wonder I couldn't find it when I lifted the car and turn the wheels.
#15 |
| grinding noise during acceleration and air condition problems | menz | DIY / Maintenance / Service | 7 | 03-28-2015 11:47 PM |
| Grinding noise in reverse | NickNickNick | DIY / Maintenance / Service | 14 | 03-15-2013 03:10 AM |
| Grinding noise with brake use | yarista | General Yaris / Vitz Discussion | 5 | 07-19-2012 11:49 PM |
| Yaris makes a grinding noise while turning | jonathankoji | DIY / Maintenance / Service | 7 | 07-06-2011 07:01 AM |
| ABS?, Grinding Noise When Brakes Are Locked!??? | p0pNfr3sh | DIY / Maintenance / Service | 3 | 03-03-2010 05:22 AM |
