Old 09-19-2015, 11:16 PM   #1
bairjo
Tire low PSI light
My low tire PSI indicator light started blinking yesterday. It started blinking then stayed on. Checked the tires... all four were at 32 psi dead nuts on. Checked the spare motorcycle tire and it was low and corrected that...even though I don't think it has a sensor in it.
Today it started blinking again and then stayed on for about 5 minutes and then went out.
Has this happened to anyone else? Do I have a defective sending unit in a tire or a bad receiving unit? Is there a reset for this system?
I really do not recall nailing a pot hole or anything like that..
Old 09-19-2015, 11:29 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
pump your tires up little more if problem still there have it scanned u may have a bad sensor just replace it , other problem maybe threshold settings if one plays with the settings it will trigger the sensors ...to fix this lower all tires to 25 psi reset sensors with button under the dash then pump tires up back to 32 psi.
Old 09-19-2015, 11:32 PM   #3
bairjo
thank you for your response. I will be trying that.
Old 09-19-2015, 11:39 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
from factory threshold is set at 25 to 26 psi so if its messed with and u reset button at 30 psi it will trigger the warning light when it drops by 2 psi ..so try the reset first if that fails you may have a bet sensor that you will need a scanner to see what one is bad.
Old 09-20-2015, 12:50 AM   #5
nookandcrannycar
Does my 3rd Gen 2014 have the same sensor reset as bairjo's 2nd Gen? My light doesn't come on until low 20s PSI wise.
Old 09-20-2015, 03:02 AM   #6
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes. Same setup.
Old 09-20-2015, 05:28 PM   #7
bairjo
is it recommended that I wait until it starts acting up again or should I just go ahead and do the reset now?
Old 09-20-2015, 08:24 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
You can do the reset at anytime
Sent from my E2306 using Tapatalk
Old 09-21-2015, 07:23 PM   #9
nookandcrannycar
Originally Posted by NYC-SE View Post
Yes. Same setup.
Thanks
Low Fuel Warning Light NYC-SE Third Gen Yaris General Discussion 18 08-18-2014 04:53 PM
low gas light... b20vteg Third Gen Yaris General Discussion 3 12-24-2012 04:34 PM
tire pressure light won't reset nikvolkert DIY / Maintenance / Service 6 10-24-2010 03:58 AM
Low Tire Pressure Sensor DebbyM46227 General Yaris / Vitz Discussion 24 10-18-2010 10:02 AM
