Old 10-06-2010, 08:57 PM   #1
nikvolkert
Drives: 2008 yaris
tire pressure light won't reset
So my tire pressure got down too low on my 2008 yaris, and after filling them back up with air the light is still on. anyone know how to reset it? cant seem to find it in the owners manual.
nikvolkert is offline   Reply With Quote
Old 10-06-2010, 09:07 PM   #2
If it was just the one tire, the light would go out once you corrected it. If the light stays illuminated, check the other tires. If it flashes for one minute, then goes solid when you start the car, then there is a problem with the system.
Old 10-07-2010, 06:32 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
some times you just need to cycle the key a couple times.... but it usually goes out as soon as all the pressures are correct. Your gauge may be off, so add a couple extra pounds to each tire
Old 10-17-2010, 04:33 PM   #4
TurnOntoTheDirtRoad
Drives: Yaris Hatchback 2009
Have you checked the pressure on the spare tire????
TurnOntoTheDirtRoad is offline   Reply With Quote
Old 10-17-2010, 05:54 PM   #5
The Yaris does not have a sensor in the spare.
Old 10-17-2010, 09:19 PM   #6
1stToyota
1stToyota's Avatar
If all else fails you could have your sensors tested to see if one of them might have failed prematurely, just takes a few seconds.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-24-2010, 03:58 AM   #7
birdman
Mine always flashes for a minute and goes out with my winter rims on. They don't have the sensors on them. One of these days I'll get around to installing CTScotts on off TPMS switch and that will be the end of that.
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 02:53 AM
tire pressure light Lorenzo1950 DIY / Maintenance / Service 4 08-23-2010 10:20 PM
tire pressure light goes on and off, on and off janices_yaris DIY / Maintenance / Service 8 07-30-2010 03:58 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
