Old 09-26-2015, 08:14 AM   #1
unadilla66
Drives: '07 3d, '10 3d, '12 3d
Shifting squeak
I've got an annoying squeak coming from the shifiting linkage when going in and out of 3rd. Any recommendations on something I can spray on the link to lubricate it that won't damage/deteriorate the (what looks like) rubber bushings in the linkages? Plain old WD40? Penetrating oil?
unadilla66 is offline   Reply With Quote
Old 09-26-2015, 11:39 AM   #2
fourbangingfun
fourbangingfun's Avatar
There is a big thread on this site somewhere that'll show you exactly where to spray some grease. It's in the linkages of the gear lever underneath the air box. It'll blow your mind how easy of a fix it is.
fourbangingfun is offline   Reply With Quote
Old 09-26-2015, 12:52 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Use lithium grease. Just have someone move the shifter about while you peer down past the airbox toward the tranny. You will see the moving parts. The junction on the right shaft is the culprit. Spray Lithium Grease there in each gear position, a couple times a year. A 10 second fix.
Melting Shifting Cables SuperVitz Performance Modifications 6 08-02-2011 05:40 AM
Squeak when braking The little red pill General Yaris / Vitz Discussion 2 04-09-2010 12:11 PM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 10:35 AM
Rough Automatic Shifting Twistoffate0817 General Yaris / Vitz Discussion 9 04-15-2009 03:48 PM
Didn't buy; awkward shifting? drmitch New YARIS Purchase Forum 89 03-03-2009 10:44 AM
