Old 08-01-2011, 08:48 PM   #1
SuperVitz
Drives: Yaris 1.5L RS TURBO
Unhappy Melting Shifting Cables
Hey
I recently modified my yaris rs 1.5l with a turbo and now im facing problems with the shifting cables because from where the shifting cables passes now there is a pipe for the turbo and its pressing the cables downwards the exhaust pipe causing them to melt.
please any solution
SuperVitz is offline   Reply With Quote
Old 08-01-2011, 08:56 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
I don't know if it would be enough to solve your problem but what about heat wrapping? You could wrap the exhaust pipe to keep the heat away from the cables and maybe the cables for added protection?
It may even boost your power by reducing engine temp. Every 11 degrees dropped = 1%whp roughly.
Old 08-01-2011, 09:23 PM   #3
KSIbucky
KSIbucky's Avatar
some type of pipe raping?
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 08-01-2011, 09:29 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Please keep your sexual deviancy to yourself.
Old 08-02-2011, 03:32 AM   #5
SuperVitz
"Altitude" LOL!!
the cables used to be heat wrapped but i'm guessing because the exhuast pipe is not, the heat was enough to destroy the heat wrapper of the cable! I will wrap the new ones i will buy and also i will wrap te exhaust pipe! but i was wondering if i can find any longer(altitude;) :P) shifting cables so i will be 100% sure that this will not happend again by passing the longer cables above the turbo pipe!
Thanks a million!
Old 08-02-2011, 03:35 AM   #6
SuperVitz
Old 08-02-2011, 04:40 AM   #7
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I had this issue on my turbo engine. Shifting cables were too close to the downpipe.
Use this for the cables - http://www.designengineering.com/cat...nized-sleeving
Use this for the downpipe - http://www.designengineering.com/cat...-lr-technology
After these make sure that the cables and the downpipe are not making contact or the cables will eventually fail even after wrapped
Paddle Shifting (for MT) Tamago Performance Modifications 95 01-31-2014 07:19 AM
Why you should not use cheap audio cables. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 14 08-01-2010 12:31 PM
"click" when shifting into park The little red pill General Yaris / Vitz Discussion 2 05-25-2009 12:43 AM
Rough Automatic Shifting Twistoffate0817 General Yaris / Vitz Discussion 9 04-15-2009 02:48 PM
Didn't buy; awkward shifting? drmitch New YARIS Purchase Forum 89 03-03-2009 09:44 AM
