Old 10-28-2015, 11:23 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
mechanical boost gauge
Where is the best place to tie in a mechanical boost gauge?
Innovative 1 is offline   Reply With Quote
Old 10-29-2015, 06:08 AM   #2
Make sure it is a combo vacuum/boost gauge, otherwise it might whistle in vacuum, like the one did that I originally installed. For installing it, the smaller vacuum hose, which connects to the intake manifold is the best place, unless your setup has a port for doing so (the Blitz SC for example has a 1/4" threaded port built right in to its manifold.)
Old 10-29-2015, 06:33 AM   #3
tmontague
tmontague's Avatar
Scott, do you happen to have a pic of the vacuum hose you recommend using to tap the gauge into? Are you talking about the one that comes from the EGR?
Old 10-29-2015, 08:41 AM   #4
Innovative 1
Power Enterprise is telling me to tie into vac hose going to p-con sub computer which is tied into vac line in between throttle body and purge valve.
Old 10-29-2015, 07:41 PM   #5
There are no vacuum lines on the throttle body - Just coolant lines. The one I am talking about is the one that goes to the purge valve, but it is mounted to the intake manifold just past the throttle body.
Old 10-29-2015, 09:06 PM   #6
tmontague
tmontague's Avatar
I see, that's an easy location to tap a gauge into. Thanks for the info
Old 10-29-2015, 11:12 PM   #7
Innovative 1
Sorry CTScott. I meant to say past the throttle body.
Grimmspeed Manual Boost Controller For Sale fnkngrv Items for Sale by private party 1 05-05-2014 01:25 PM
FS: AEM FIC / TRUE BOOST GAUGE / CONTROLLER TOLMACH Items for Sale by private party 12 11-07-2013 11:12 PM
Boost gauge install in yaris guide? thatbryanguy Forced Induction Forum 7 07-30-2013 11:55 AM
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
What boost gauge do you run? Bluevitz-rs Forced Induction Forum 7 07-19-2010 09:00 PM
