Old 07-29-2013, 08:40 PM   #1
thatbryanguy
Drives: Yaris 3dr hatch
Boost gauge install in yaris guide?
Looking for some help on how to install a boost gauge in the Yaris. Any guides already written? (If so I couldn't find it with the search function) and opinions on the best or most accurate boost guage.
thatbryanguy is offline   Reply With Quote
Old 07-29-2013, 09:17 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
explain further what you are looking for?
Old 07-29-2013, 09:35 PM   #3
thatbryanguy
I need a way to monitor what PSI I'm at while I'm driving but I'm not sure what brand gauge to buy or what vacuum lines I'm even supposed to tee the boost gauge into like the Maf lines or something? Could I intersect where my AEM FIC is plugged into or something? Or would that have an affect on the FIC?
Old 07-29-2013, 10:01 PM   #4
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Are you running a turbo or a Blitz?
Old 07-29-2013, 10:24 PM   #5
thatbryanguy
Zage turbo kit
Old 07-29-2013, 10:50 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I went with the AEM 0-15 psi analog gauge. I haven't run the wires through the firewall yet, but there was already a threaded hole in the Blitz manifold. I'm planning on mounting the boost and AFR gauge inside the driver's glovebox so that they're in "stealth" mode until I need them.
Old 07-30-2013, 12:16 AM   #7
I have an Autometer analog vacuum/boost gauge (I initially bought a boost only gauge, but got tired of it making sucking noises when I was not in boost).
I mounted mine in the face of the drivers side glove box cover and ran the tubing through a hole I drilled in the back of the glove box, and then through the large grommet on the firewall, behind the battery, to the Blitz manifold.
For power, I connected it to the pink wire on the ignition switch connector (ignition switched +12). I connected the illumination wires to the dimmer rheostat connector: Brown (illumination power) and green (illumination ground).
Old 07-30-2013, 11:55 AM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'll be running the AEM tru-boost that Garms sells.
-Type 07 FFL-
My odometer 03/11
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2008 Yaris Fog install ReMiX Cosmetic Modifications (Exterior/Interior) 8 12-19-2008 12:30 PM
