#37 | |
A Richard Petty driving experience, and something that sounds like street racing. You are so overqualified.
#38 | |
0-60 in slow
2014 BSpec Divisional Champion |
#39 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Yeah, I try n use the gears, rather than stand on em in extreme circumstance, not as often as this thread makes it out to be.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
#40 | |
Actually, I started this thread, as there really was no real stickie or good info on other options or any options for that matter and wanted to help myself and others, as to what is available, didn't really start the thread for a bashing by the almighty racing clown, then get bashed again. I have more than 480 certificates (in multiple manufacturing brands) in automotive, electrical and tires and do not claim to be the know it all, actually try and help, and be helped. I have been working on cars since 83 helpin pa, 84 in school, then on personal or girlfriends cars until 89 then part time until 97 then full time since then, but, dude, I do not claim to be all knowing. I came here looking for tips and tricks, saving me time and helping others when I can, as much as I can. There are some good techs on here that we want their advice, what they did on their brakes and what they recommend. I merely also stated what I was doing as well. Feedback good and bad is good. Fail troll is not. So, you are either here to help or to not. So far though Lets turn the thread back into what we all can do to have the best brakes and the cheapest way to do it. As well as some pretty ones and some racy ones and plain jane ones. And newer Yaris ones, or older Corolla ones. And so on. Lotsa good input so far from many thanks. Hopefully no more bashing from the race clown: barf:
#41 |
Although I appreciate your approach, agree the thread should get back to the initial purpose, and am by no means a grease monkey myself, I think some validity has to be given to Jason and Armstrong given the fact that they are currently pushing these vehicles in real world race events, which is where auto manufacturers have learned the most about what works and what doesn't. Again, I'm no expert and I say it with all due respect, but I can't imagine a situation in daily driving or aggressive street driving where more would be revealed about the brakes on these cars then on the track in national events. Further to that, not just on the track in national events, but winning those events with fully built Yaris' running OEM brakes.
Just my 2 cents. |
#42 | |
![]() You can't help those that have made up their mind despite evidence to the contrary. Some guys are just so "street" they can't believe they are doing it wrong. Lol
#43 |
Have to agree w/ JimKelly. Let's put the junk junk back in the pants and stop trying to compare lengths.
All input on this forum is appreciated and yes especially from those that race and are damn good at it. However, for the sake of everyone's gain, let's try and keep the ego's away...this is an Internet forum...let's be honest. In the relatively short time i've been on this forum i've been able to learn more about cars than I ever thought I would. Without the input from various perspectives it wouldn't have happened. Just keep it clean and to the point of the original post and it's a win.
#44 |
Mr. 155 and climbing
All I know is that I am not happy with the OEM brake performance with what I do for racing. I will need to look into that swap.
Sent from my XT1575 using Tapatalk
#45 |
I have driven on the Max brakes for a few months now. Overall, I will be going back to my Toyota brake pad and rotor set up when done with these. I did machine the rotors and then painted them, and placed them somewhere in my humidity/temp controlled shed, laying flat. Ditto with the wifes Camry front rotors. I have found, from customers cars as well as my own, the pulsation concern lies with the sliders needing to be re-lubed, pending use and water drive through, etc., but typically at least at half pad life. Then for us Yaris owners, to make sure also to have rear brakes adjusted out as needed.
The Max brake comparison in my opinion, they shine over two areas only, severe panic stop and less brake fade when warm. The variable here could be I also upgraded my brake fluid on some of the fade concern, but also, I was on the lower half of the stock pads too. But, regular braking, they perform weaker than the stocks. I believe the slots and drills provide a tick more grab on panic stops. Next go around, I will put stock pads n rotors back on, but also do another brake flush with same synthetic fluid to rule out variable in fade. That said, the Max brakes were a tick cheaper with rotors and you get what you pay for, really. A tick cheaper set up. OK, but not great and going back to stock says it all. Hope this helps. If Wilwood or the like made a set up, then maybe go for that. I did also change springs and struts, this also assists in braking less nose dive.
#46 | |
I work on cars all day. N drive 80-100 miles/day in crazy (as it is everywhere) rush hr traffic, typically with the more aggressive approach.
#47 | |
#48 |
Well, I made it to 198K miles, and the rotors held up well, only pulsate if really rompin on it. Normal braking ok. But, I am down to 4 mm on the pads, and have a low pedal. RFear brakes finally changed last night before I left work, they were a wafer on primary shoe, so done. The rotors did wear about half of my slots away. Not having great bits on the lathe, and prolly taking most of the slot away if machined, I am gonna toss the maxx brake rotors n pads. I would say, all in all not bad, normal stopping not as good as stock and emergency stopping better than stock, but not by much....I have my OEM rotors I had previously machined and painted and stored flat, so they will go back on tonight with factory pads (like my shoes, factory). Then I will bleed n flush brake fluid again tonight or soon, pending pedal feel. So, that said, I would go with maxx brakes again, but the factory pads are a cheaper option for me currently, so doin that.
| new brakes or some bs upsell? | scene | General Yaris / Vitz Discussion | 23 | 02-12-2012 11:03 PM |
| general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 03:20 PM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 01:04 AM |
