Old 11-21-2015, 03:43 PM   #1
tomm9050
Drives: Yaris 2008 HB
Engine Dust Cover
I just changed spark plugs (07 HB) and before I reinstall it, are there any pros or cons of not using the engine dust cover?
tomm9050 is offline   Reply With Quote
Old 11-21-2015, 04:12 PM   #2
tmontague
tmontague's Avatar
There have been reports of water getting into the coil holes causing misfires. That being said most of those cases happened with the cover still on.
No real issues except dirt getting on valve cover as opposed to the dust cover.
I remove mine during the summer and install it again in the winter
This is more for aesthetics as I have my valve cover and coils painted. But that's about it
Old 11-21-2015, 09:58 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
I removed mine to let as much heat out. Any heat that stays under there is just making your ignition coils etc hotter, which will shorten their lives (as well as make wires and plastic connectors more likely to crack). The only reason I would consider putting it back on is if I was planning on driving through mud in it..... not likely. Also saves a teeny bit of weight.
Cheers.
Old 11-22-2015, 08:34 AM   #4
bronsin
bronsin's Avatar
Id put it back to protect the coils from moisture.
Old 11-22-2015, 03:21 PM   #5
tomm9050
How would it protect them from moisture? So Cal car, so moisture is not a huge issue.
Old 11-22-2015, 03:29 PM   #6
bronsin
bronsin's Avatar
I guess if it never rains theres no problem. But the wires going to the coils are pretty exposed under that plastic.
Old 11-22-2015, 08:45 PM   #7
CoryM
Another pro would be that rodents are less likely to make their home there with the cover gone. They tend to nibble on things and can get very expensive.
The wires, connectors, and coils are all weather-resistant. The only viable way for water to cause an issue is if it gets under the seals of the coils and into the sparkplug tubes. Again, they are sealed to prevent this. I live in Vancouver BC. If water was an issue, I would definitely know about it.
Old 11-22-2015, 09:45 PM   #8
tmontague
tmontague's Avatar
Dielectric grease on all electrical connectors, especially the spark plug tubes are a big help.
Old 11-23-2015, 07:03 AM   #9
bronsin
bronsin's Avatar
Originally Posted by CoryM View Post
Another pro would be that rodents are less likely to make their home there with the cover gone. They tend to nibble on things and can get very expensive..
I ride motorcycles for 40 years and STORING a motorcycle for the winter (when it sits still for a few months) is an open invitation for this to happen. The damage they can do can be devastating.
For this reason I always recommend, especially if you live in a rural area, you put traps out for the critters. Mice cant resist peanut butter so a spring trap baited with it works a treat. But poison and sticky traps also work good. I recommend all three. Also, check the traps at least weekly and reset if (when) you catch some. If you do catch mice this will alert you to the potential problem and you better take action.
I think it unlikely for this to be a problem for something like a Yaris which is always in use. But if it sits in winter for any length of time....LOOK OUT!
Old 12-18-2015, 11:50 PM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I haven't used the OEM cover for 5 years
Sent from my XT1575 using Tapatalk
Old 12-19-2015, 06:53 AM   #11
bronsin
bronsin's Avatar
I just serviced my plugs and there were dried out kernels of corn under the plastic cover! There isn't a farm within 30 miles of my house either.
Old 12-19-2015, 09:12 AM   #12
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Haven't used mine for 10 years. Have never had any problems with water or dirt.
Old 12-19-2015, 12:01 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
I've driven year around with mine removed and have had no issues.
The latest was a MI grey anodized cover adapted for the Blitz S/C. It often made a annoying buzz at idle. Rubber isolating washers didn't help so now it's on the shelf.
Old 12-19-2015, 04:30 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Engine covers for most part are just for cosmetics, hold heat and great place for mice to live I'm running with out one.
Sent from my Samsung Galaxy S6
Old 12-19-2015, 06:55 PM   #15
bronsin
bronsin's Avatar
Huh I will consider not putting mine back after Im done servicing the plugs.
Old 12-19-2015, 08:55 PM   #16
mehullica
Drives: Yaris 3-door
It slightly reduces top end engine noises
mehullica is offline   Reply With Quote
dust cover
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
TS engine cover? cali yaris Yaris TS Talk 17 11-07-2009 04:54 AM
Question about painting the Engine Cover Blue_dragon_192 Cosmetic Modifications (Exterior/Interior) 11 08-05-2009 12:45 PM
Injen polished engine cover cali yaris Items for Sale by private party 3 07-06-2009 11:15 PM
WTB Stock Engine Cover whooppee777 Willing to Buy by private party 8 02-24-2009 05:05 PM
