#1 |
![]() ![]() Drives: 2009 Yaris 4dr Sedan Join Date: Mar 2009
Question about painting the Engine Cover
A couple of simple questions.
1) How long can I drive my car without the cover on? Is it just a cosmetic item or does it protect the plug wires and everything there? 2) On the cover where the 4 screws hold the cover in place, the top two holes have Metal retainers with rubber grommets in them. How do you remove them, or is it ok to paint over them. I am keeping with the Black and Red thread of my interior (BSP paint, Black interior, and RED LED's), with the engine cover (Red cover, Black lettering and Logo). Let's see how this goes.... Blue. |
XBL: Jeemee Ghost
I don't know if it actually protects anything, but I've had mine off since I've had the car which is over a year and never have had any problems. I have no idea how to remove the grommets, though I'm sure it's fine to paint them.
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
#3 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
I guess it's there to protect the engine in the event your hood is up and there is precipitation or anything.
#4 |
Slowy getting there
I wash my engine with the hose and I don't have an engine cover on mine.
#5 |
Thanks all.
Now on to getting it prepped and then painted. |
#6 | |
#7 |
be gentle with the red paint ;) keep it clean!
Been a long time messing with cars.. |
#8 |
Tamago, I will be gentle.....It's going to be all red, and the logo and vvi in black.
If not, then sand and paint black again..... |
#9 |
On to my next questions.
I have sanded the cover and will use a tack cloth to clean it up. On to the questions. Where do you find the hi-heat primer and paint (paint I can find, but in black only). Or can I paint it with regular paint and then use a high heat gloss (clear)? |
#10 | |
#11 |
Thanks CTScott!!!!!
#12 |
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
You might condsider an engine or exhaust pait as they are sticky, heat resistant, and tolerant of petrochemicals
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Engine cover for S/C engine | LtNoogie | Cosmetic Modifications (Exterior/Interior) | 84 | 05-04-2009 08:41 PM |
| FS: OEM Engine cover | kustom play | Items for Sale by private party | 0 | 03-21-2009 08:59 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
