![]() Drives: Toyota Yaris 2014 LE Join Date: Dec 2014
Lower Knee Panel Removal
I've tried and tried but I just can pry this panel off. I can remove the air flow panel on the top with no problem, just by pulling it off. I glared inside and I can see that the only things holding this panel in are several taps similar to the air flow panel I pulled off. Help please!
#3 | |
![]() How would you recommend going at the two clips in the two circles? Should I just start by pulling away the bottom and then work my way up without the use of any prying tools, or is there a method?
I think those are the easy one. The triangle ones are the really tight ones, where you may need some serious prying force to pop them.
If what I saw was correct, the triangles should consist of the same yellow tabs as the ones on the stereo and overhead trims. I'll give them a good yank and some prying tomorrow and see how it goes. (〜 ̄▽ ̄)〜
I removed this panel simply by pulling it straight out. Put your fingers in the recess, grip below that with your thumb and PULL HARD up towards you. Pull in the same angle that the shelf in the recess slopes at. (Hope that makes sense). It requires some effort, just when you think you are about to break something and should stop is when it will pop out.
I followed CTScott and NYC-SE's advice and was able to pull the lower knee panel off. Here is the method that worked for me; however, I am sure there is a better method, and most likely safer too.
![]() ![]() Be careful here. Do not pull forward excessively, because I did so initially and the lower portion cracked. What you're going for here is full fingers support on the backside of the panel. Only then should you pull forward; if necessary. ![]() ![]() I hope this helps; for anyone who may need to remove this panel in the future. |
Glad you got it off. Just curious what are you doing back there? (I took mine off to get to body ECU and wire up mirror turn signals).
#9 | |
| Tags |
| lower knee panel, panel removal, trim panel removal |
| Help! Right side lower control arm removal | RUBBERDIPSTICK | DIY / Maintenance / Service | 15 | 12-27-2018 01:29 PM |
| Rear door inner panel removal. | mrpj | Third Gen Yaris General Discussion | 2 | 05-10-2014 04:13 AM |
| DIY rear Interior panel removal 09 3dr LB | bkndacn | Cosmetic Modifications (Exterior/Interior) | 10 | 03-11-2013 01:05 AM |
| Yaris 1.0L GS 2000 Driver's Door Panel Removal | milooshea | DIY / Maintenance / Service | 3 | 01-30-2011 12:20 PM |
