Old 01-29-2011, 03:32 AM   #1
milooshea
Drives: Toyota Yaris 1.0L GS 2000
Yaris 1.0L GS 2000 Driver's Door Panel Removal
I need to replace a driver's door mirror that a speeding, inexperienced driver smashed when passing in a country lane. Bolts visible but inaccessible without removing the interior door panel.
The information and photos posted about the newer models are helpful and encouraging, but unfortunately don't match up fully with my Y2000 model. I've removed 2 panel screws and the screws holding in the latch assembly and finger grip, but everything is still rock solid. Window control unit comes out easily, but no screws underneath it. Do I need to remove the door catch unit or are there screws concealed somewhere else? Or is it a case of just twisting the whole door panel up and clockwise from the bottom lefthand corner?
Grateful for any advice and help anyone can offer.
Thanks in advance,
Milo
milooshea is offline   Reply With Quote
Old 01-29-2011, 08:16 AM   #2
This should help:
Old 01-29-2011, 09:17 AM   #3
If you have the 2 screws out and the 3 plastic clips out then just pull hard from the bottom and it'll pop free.
Old 01-30-2011, 12:20 PM   #4
milooshea
CTScott & Bluevitz: many thanks for the helpful advice and pics - it worked exactly as described.
Regards,
Milo
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
