![]() Drives: yaris 2007 Join Date: Feb 2016
ABS light on. Help.
The other day I had to press my brakes hard suddenly and right after my abs light came on. I thought maybe it was just letting me know that my abs brakes were just enabled but my light will not go off. I reset it twice via scan tool but after about 10 seconds of no light, it comes right back on. It is ONLY my abs light. I took it too toyota and they said its either my wire or my sensor in my front left of the vehicle and want lots of money. Any help is extremely appreciated. Why is it all of a sudden broken from having to actually use my brakes ??
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
They go bad. Can be damaged by road debris. Plug and play install.
#4 | |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
No lift here, so wheel always comes off. It's a good time to check the brakes also.
If you can get to the back of the hub area, look for the sensor cable.
I find it easier to remove the tire and get a light in there but you may be agile enough to lay on the ground. I never replaced one on the Yaris but I have on others. Should just plug in on both ends. |
| yaris abs brake light speedometer and electric powersteering issues | dave van muyden | DIY / Maintenance / Service | 4 | 10-26-2013 02:33 PM |
| Resetting abs light on 58 plate yards | jackg205 | DIY / Maintenance / Service | 1 | 06-24-2013 06:43 AM |
| HELP / Spoiler connecting light | SimTronik | DIY / Maintenance / Service | 4 | 11-02-2010 11:08 PM |
| Parking Light Flash Output vs Hazard Light Output | sex | DIY / Maintenance / Service | 2 | 11-03-2009 08:47 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
