#19 |
awesome, CarboTech is the shizzle for brakes!!
#20 |
please don't ever say that word again,
it just doesn't sound right
#21 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Just a couple more tips for the M8 forcing screws. 1) blow out or tap the M8 holes before using them. 2) Be sure to use anti-seize on the threads of the forcing screws. 3) Put some pre-load torque on the screws, Then go around the rotor beating on it. If you alternate between tightening the jacking screws and beating on the rotor no rust can defeat you. A little heat on the rotor bore never hurts either if you happen to have a "hot wrench" (oxy-acetylene torch).
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
#22 |
Drives: 2009 Toyota Yaris Base Join Date: Dec 2014
Has anyone determined that M8 bolts will in FACT fit the threaded rotor holes?
#23 |
I have a couple of bolts that I use, but I don't have access to them at the moment to check. Most Japanese cars use M8x1.25, but for some reason I want to say that the Yaris uses fine pitch (M8x1.0). Just buy yourself two of each to be safe.
#24 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Tried to replace the front rotors today, and ran into the same problem with rotors rusted to the hub. Neither one of the front rotors wanted to came off. I tied the BFH method, but no luck. I also suspect the threads of the jacking-bolt holes are rusted to the point where if I try to use jacking screws, they'll just strip right out...
![]() For now i've changed out the pads, but the rotors are warped and I want to change them out as well. Any other suggestions on what I can try?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#25 |
Big hammer give it a good hit from behind or bolts in front to push rotators off...but one good hit with hammer works great lol
Sent from my ONE A2005 using Tapatalk |
| DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
| Removing front bumper | fat45s | DIY / Maintenance / Service | 1 | 01-31-2007 06:25 AM |
| removing front plate | Lowfront | Cosmetic Modifications (Exterior/Interior) | 19 | 08-25-2006 09:59 PM |
| Removing third brake light | lightyearsgirl | DIY / Maintenance / Service | 8 | 08-06-2006 11:26 AM |
