Old 05-26-2016, 12:04 PM   #1
bronsin
bronsin's Avatar
AC Not Working: What Should I Do?
2009 hatchback, 44 k miles. I seldom use the ac, mostly in winter for defrosting.
Is there anything I can check myself? How does one troubleshoot the ac and what tools are needed?
Thanks!
Old 05-26-2016, 12:25 PM   #2
tmontague
tmontague's Avatar
Buy a pressure reading gauge, it will have a high and low side and allow you to see if you are low in coolant.
If you seldom us the a/c then changes are it is a seized compressor, but i'd first check the pressure of the coolant, this will also show if you have a leak.
That is why a/c should be run every week or so even just briefly. Keeps the oil in the coolant circulation through the compressor so it doesn't seize
Old 05-26-2016, 12:27 PM   #3
bronsin
bronsin's Avatar
In winter it is but I'm not so good about summer.
Where do you hook up the gauge?
Will the gauge show a bad compressor?
Old 05-26-2016, 01:18 PM   #4
bronsin
bronsin's Avatar
Checked my 2001 ECHO SERVICE MANUAL and first thing it says is check the sight glass for bubbles.
Yep lots of bubbles..
Old 05-26-2016, 02:18 PM   #5
tmontague
tmontague's Avatar
On my sight glass it say I should see bubbles after use, but i've never really been able to see them, I don't trust that thing all too much.
You hook up the gauges to the high pressure side I believe. Not 100% sure but there iis , few good videos online about it.
It won't show a bad compressor per say but it'll help you point to that direction if that is in fact the issue
Old 05-26-2016, 06:32 PM   #6
Sirius-XM
Toyota (TM) Shareholder
Sirius-XM's Avatar
Drives: 2007 Jade Yaris Sedan
You have a couple options as far as a gauge. You can get a professional set that hooks up to both the high and low side or a can of Freon that comes with a gauge and hooks up to the low side.
Although technically a sealed system, over the years some Freon may leak out. I added a little Freon two years ago and has been fine since. Keyword is little, too much is real bad. If you go the Freon can route I would go no higher than the beginning of the green area on the gauge when adding freon. Look for one that has sealant and seal conditioner.
Bubbles is generally a good sign as it means the freon is moving and hasn't all leaked out.
Sirius-XM is offline   Reply With Quote
Old 05-31-2016, 12:50 PM   #7
bronsin
bronsin's Avatar
Toyota has the Yaris. They're going to pull a vacuum on the system after sucking it dry and see if the vacuum holds. This is $190.
Hmm the classic deal is do this then the system runs dry and its mo money for another component.
I ll let you know.
I like pulling the vacuum and wait and see if it holds. Hopefully they wait a year or so.
Old 05-31-2016, 02:38 PM   #8
tmontague
tmontague's Avatar
As a side. I checked my a/c window after using it for 20mins. There was no bubbles and then I moved/tapped the viewing glass and bubbles appeared a stayed.
So I guess the bubbles do work but may need to be helpe with some movement for them to show
Old 05-31-2016, 04:18 PM   #9
bronsin
bronsin's Avatar
Huh well here's the deal.
Toyota call ED space and said they drained and filled the system and found no leaks . They want me to come back in 500 miles and check again for leaks.
Im guessing they put dye in there in case it leaks.
Seems like a possible setup for more work for them to do and get paid for.
This is why you want to DIY but I'm to old for that anymore.
Old 05-31-2016, 05:42 PM   #10
bronsin
bronsin's Avatar
Yep they put dye in.
Also they did a 10000 mile inspection for free and found nothing wrong and wrote it up. I think they get $300 for that.
Electronics randomly not working - NEED HELP! scoobopdan DIY / Maintenance / Service 5 12-17-2015 08:25 PM
Remote Fob and Stereo Stopped Working after Fuse Change Ruud DIY / Maintenance / Service 6 03-12-2015 08:15 PM
Electric Windows Stopped Working !?!? MattyP DIY / Maintenance / Service 0 09-14-2010 08:20 AM
Working at Volkswagen elsteverino889 Off-topic / Other Cars / Everything else Discussions 22 05-07-2007 08:29 PM
