Old 05-25-2016, 06:40 PM   #1
Rylinkus
Drives: 2012 Mitsu Ralliart Sportback
07 Yaris Rear Lock
Basically the rear lock on my Yaris has seized. Looking for a dirt cheap replacement. 2 door hatch, manual lock.
Rylinkus is offline   Reply With Quote
Old 05-27-2016, 03:10 AM   #2
B.B._07
Drives: 07 5dr
Have you tried to flush out the lock with WD40 or spray silicone lube? The rear hatch lock on my 07 was quite gummed up before I cleaned it with silicone lube, although it was not seized. WD40 or silicone lube is not recommended as a lock lubricant (you're supposed to use graphite lubricant), but it does a great job of getting a lock moving.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Yaris with rear disc brake from factory? tamrat DIY / Maintenance / Service 18 01-19-2016 10:08 AM
My Yaris don't lock the steering wheel xilef1025 Third Gen Yaris General Discussion 5 11-23-2013 11:09 PM
2006-2011 Yaris Liftback Intermittent Rear Wipe Module CTScott Items for Sale by private party 5 12-28-2011 12:28 PM
