#19 |
![]() Drives: 2009 Yaris Join Date: Dec 2008
Ok, trying to look through the corrosion on the upper strut in the first photo. The bushing appears to be blown, and both top nuts appear to be over tightened. You have 14 threads showing from the top of the second top nut. That's an inch, at least, when the preset distance from the top of the lower nut should be half of that. The excess clamp pressure didn't help the bushing life, and it also shortened the dampening stroke on the strut.. the low level banging you first heard when you installed the rear Tein shocks could be coming from this (I made the same error, not to the same degree, on the Bilstein's.. a bit of banging over bumps. Found that the distance was about 3/4"' likely when I over-torqued the nuts. When I checked and reset this distance to about 1/2" from the lower strut but, the noise went away).
The Tein coils appear to be adjustable. Not to sound like a heretic, you might consider loosening those up a bit, increasing the amount of spring dampening. |
#20 | |
![]() Drives: yaris Join Date: Jan 2016
So i have two choice...
First i bought a rear strut bar to reduce the pression on each side or if the sound still there after i will install the strut ill jack the coilover for more space on the shock Quote:
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 07:52 PM |
| Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-22-2011 08:32 PM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 12:52 PM |
| WTB: Strut Bar, Rear Brace, Lowering Springs, Etc. | yaya | Willing to Buy by private party | 8 | 05-29-2009 10:26 AM |
| Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? | thomasward00 | General Yaris / Vitz Discussion | 3 | 07-12-2007 02:22 AM |
