Old 05-28-2016, 11:25 PM   #19
Tapokata
Drives: 2009 Yaris
Ok, trying to look through the corrosion on the upper strut in the first photo. The bushing appears to be blown, and both top nuts appear to be over tightened. You have 14 threads showing from the top of the second top nut. That's an inch, at least, when the preset distance from the top of the lower nut should be half of that. The excess clamp pressure didn't help the bushing life, and it also shortened the dampening stroke on the strut.. the low level banging you first heard when you installed the rear Tein shocks could be coming from this (I made the same error, not to the same degree, on the Bilstein's.. a bit of banging over bumps. Found that the distance was about 3/4"' likely when I over-torqued the nuts. When I checked and reset this distance to about 1/2" from the lower strut but, the noise went away).
The Tein coils appear to be adjustable. Not to sound like a heretic, you might consider loosening those up a bit, increasing the amount of spring dampening.
Tapokata is offline   Reply With Quote
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
WTB: Strut Bar, Rear Brace, Lowering Springs, Etc. yaya Willing to Buy by private party 8 05-29-2009 09:26 AM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 01:22 AM
