![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
2ZR-FE CARTRIDGE OIL FILTER TO METAL OIL FILTER
Recently I found that Toyota is going back to metal filters and so decided I would swap my 2zr-fe motor too.The swap to metal filter is very simple but the parts might set you back a little.I took my parts from a scion im because I wanted japan built parts but a 2016 corolla will work as well(USA part numbers
are different.) Here are the japan part numbers used 1 X bracket, oil filter 15609-37010 2 X gasket,o-ring 96723-24020 1 X oil filter Union 90904-04006 1 X (japan)oil filter 90915-10004 REUSE 4 MOUNTING BOLTS Basically you unbolt the 4 bolts holding the filter assembly and then change the 2 O-rings, after that just bolt the new filter assembly. |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Missing oil filter = engine locking | Ball3rina | DIY / Maintenance / Service | 5 | 06-20-2012 01:30 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 05:27 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 03:56 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
