![]() Drives: 2010 Yaris 3door black sand pe Join Date: Sep 2011
Where are the best points for jack stand placement on the three door Yaris? Thanks to anyone for this info.
![]() Drives: 2016 Yaris 5 Door LB Join Date: Jul 2016
I used the rear subframe "bar" on the rear just forward of the gas tank and two placed under the control arms up from just where they meet the subframe. To avoid any mishaps, drive your car up on ramps, use the center jack point on the subframe to lift the front and place thr stands. After the front is supported, lift the rear.
Works like a charm and I used this method and these locations when performing thr brake fluid and antifreeze flush on my wife's 2011 LB. Sent from my SM-G930P using Tapatalk |
Thanks for taking the time to answer my question, bigdog2k7. I'm ready for new brake fluid and an antifreeze flush also.
| Rear point jack issue | bikegerm | General Yaris / Vitz Discussion | 11 | 09-25-2024 03:55 AM |
| Does the Toyota Yaris come with a jack? | RMcG | Third Gen Yaris General Discussion | 7 | 08-20-2015 12:03 PM |
| Jack Stands, Floor Jack and Oil Filter? | 268i | DIY / Maintenance / Service | 11 | 08-03-2014 05:32 AM |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 06:33 AM |
| Coud someone post pictures of the jack points on the Sedan & Hatch | voodoo22 | DIY / Maintenance / Service | 4 | 11-08-2008 09:24 AM |
