Old 08-11-2016, 09:27 AM   #1
Yarisandro
Drives: 2010 Yaris 3door black sand pe
Thumbs up Jack stand placement
Where are the best points for jack stand placement on the three door Yaris? Thanks to anyone for this info.
Yarisandro is offline   Reply With Quote
Old 08-14-2016, 10:55 PM   #2
bigdog2k7
Drives: 2016 Yaris 5 Door LB
I used the rear subframe "bar" on the rear just forward of the gas tank and two placed under the control arms up from just where they meet the subframe. To avoid any mishaps, drive your car up on ramps, use the center jack point on the subframe to lift the front and place thr stands. After the front is supported, lift the rear.
Works like a charm and I used this method and these locations when performing thr brake fluid and antifreeze flush on my wife's 2011 LB.
Sent from my SM-G930P using Tapatalk
bigdog2k7 is offline   Reply With Quote
Old 09-25-2016, 04:17 AM   #3
Yarisandro
Thanks for taking the time to answer my question, bigdog2k7. I'm ready for new brake fluid and an antifreeze flush also.
Rear point jack issue bikegerm General Yaris / Vitz Discussion 11 09-25-2024 03:55 AM
Does the Toyota Yaris come with a jack? RMcG Third Gen Yaris General Discussion 7 08-20-2015 12:03 PM
Jack Stands, Floor Jack and Oil Filter? 268i DIY / Maintenance / Service 11 08-03-2014 05:32 AM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 06:33 AM
Coud someone post pictures of the jack points on the Sedan & Hatch voodoo22 DIY / Maintenance / Service 4 11-08-2008 09:24 AM
