Old 10-06-2016, 04:43 PM   #1
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
Indicator / turn signal question.
Hey guys
I've recently had a retrofit job done while I was in the USA and had to buy spare headlights there and they have different turn signal sockets to the ones we have in the UK. I was wondering if anyone would know of any adaptors I could use to get my PY21W (offset bayonet) to what the new one is. Or is there a way of rewiring my original wiring to this socket so I can use that? They both are very similar but mine is too big for the US socket (T2 perhaps?)
Here's the photo from the US one
And a stock image of the PY21W socket
The forever growing to do / to buy list:
FIX Projectors - FINALLY DONE!
XB LED fogs - Done
Lowering springs - Done
MOMO Revenge Evo X - Currently selling body parts for
Declare bankruptcy - Done
Eren_13 is offline   Reply With Quote
Old 10-10-2016, 11:35 PM   #2
SirDigby
Drives: 2007 yaris 3 door
nope. you will have to order the proper socket... or rewire it with individual pins
Old 10-22-2016, 01:32 AM   #3
Eren_13
Eren_13's Avatar
Thought so. Have you or does anyone have any advice on wiring these to my original wiring? I only have positive and negative on my indicators. I'm guessing the third on these is for a DRL function? Not mentioned here but in a separate post, these are USA spec headlights and my originals are from U.K. so the wiring is slightly different I believe. Thanks for the reply!
XB LED fogs - Done
Old 10-22-2016, 12:45 PM   #4
SirDigby
it's just a different bulb, right? why can't you use the proper bulb/socket combo?
Old 10-27-2016, 09:29 AM   #5
Eren_13
Eren_13's Avatar
The two sockets are different. The one I have is too large for this headlight as they're different specs. Would you happen to know how to wire to this socket? I only have 2 wires from my indicators and this has 3 pins so just wondering which one is positive and negative. Thanks for the replies.
edit: should point out that the top image of the 3 pin is the back of the socket as it's not attached to anything yet and the bottom image is where the bulb sits in.
XB LED fogs - Done
HB Common Door courtesy switch signal? Yaross DIY / Maintenance / Service 2 01-25-2011 11:57 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 12:04 PM
Help choosing sub Duckywitbigfeetz In Car Entertainment + Electronics (audio / video / alarm) 40 03-31-2010 12:06 PM
