#19 |
#20 | |
#21 | |
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2016
We were in the shop at home. No external noises, aside from the engine cranking, to cover the noise of the fuel pump. It was not running. I guess if there is power to the pump while the engine is cranking, and there isn't a hum from the tank, then that seems a pretty strong sign the pump is shot. I figured if it was something else, I could return the fuel pump. Before I dunk the new pump in the tank, I can hook it up and see if it comes on. Anything else I should be checking or doing while I have this open? Thanks, Russ |
#22 |
Update:
Went and bought a Lisle - Fuel Tank Lock Ring Tool after figuring the retainer was NOT coming off without something. Followed the instructions on the manual I downloaded from here to replace the pump. With the tool, the entire thing was only about a 1 hour procedure. In the end, the Yaris fired right up and pulled itself out of the shop under it's own power. Success! Now just need to take it out on the road for a test drive. Thanks to all who helped me. Russ |
#23 |
So can you now hear the fuel pump activating? To be honest, I can't say as I've ever taken note of any fuel pump "sounds" coming from mine. No idea what it should be sounding like. Maybe one day I'll try to listen for it.
#24 |
Excellent!
#25 |
Awesome. Glad you were able to fix it yourself too.
#26 | |
Even buying a tool I'd HOPEFULLY only have to use once, I think I came out WAY ahead. $266.78 (RockAuto) for the pump (including expedited shipping) and $42 for the tool (sourced locally). One major chain store had the pump @ $400! Can't IMAGINE what going to a professional shop would have cost.
Now I just need to build my confidence by taking it for a drive. On a side note, I'm curious as to if the weak pump affected fuel economy. Time will tell. Quote:
Russ |
#27 |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
I think the first thing I would check is if it is getting spark at the plugs.
#28 |
#29 | |
Read first, then respond. Sent from my iPhone using Tapatalk
| Tags |
| cranks, dead, pump, won't start |
