Old 10-03-2016, 08:19 PM   #1
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
2007 Toyota Yaris Died and won't start
Good evening!
I purchased my Yaris a couple months back and have had no major issues with it. It has 110,000 miles on it. Tonight, leaving work, I made it a block away before it died and would not start.
Luckily, I was able to coast it back to the building and get it off the road. I have been reading a few posts on here trying to get a starting place. I saw this page as well: http://www.yarisworld.com/forums/showthread.php?t=45663
First off, it cranks fine. The engine light didn't come on. I don't have an Engine Immobiliser System. I checked all of the fuses by the battery and didn't see any problems.
I can sit in the car and put the key in the "Run" position. Should I hear the pump run for a second or two? Because I don't.
On sitting here reading these, in the past, occasionally it has cranked a bit more than I thought normal before starting. But having bought it used, I didn't have a "gauge" as to what is normal.
The car is a 5 spd hatchback if that helps any. I'm going to borrow a company car to go home and look at this tomorrow.
Cigar_Maverick is offline   Reply With Quote
cranks, dead, pump, won't start
