![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Straight pipe after cat rust
my cat? its rusted inside out..its making loud tinging noise when idle or accelerate...i was going nuts...i found some shops that does full exhaust but its $700...plus gains only about 5whp...i dont want their full exhuast cause i already have an aftermarket header...
anyways i went to HKS exhaust shop...supposly they do all kinds of exhaust modifications...paid $50 and they cut off the rusted part, replaced them with matching diameter straight pipe noise level: sound increased to slight bumble bee noise..no, its not like honda vtec on straight pipe.. performance: some are arguing how they lost power but i didnt lose any hp..20161029_142159.jpg20161029_141815.jpg Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
but now without a cat your car will stink... like an old turd car
#3 | |
🌽🌽🌽🌽🌽 Sent from my SM-J710F using Tapatalk
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
If you remove the cat computer will give engine a richer fuel mixture, will use more gas and turn check engine light on. I think you can get ox sensors that will lie to computer to keep cel off but still may run rich.
#5 | |
we all breathe the air...put a cat back on
im running on corn oil...no polution here...😇
| Straight pipe | rabbito | General Yaris / Vitz Discussion | 2 | 10-23-2016 02:16 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Benefits of Removing Cat and Running Straight Pipe? | Nexus1155 | Performance Modifications | 68 | 03-29-2012 01:00 AM |
| 2.5' First Cat Straight Pipe with Greddy Ti-C | gwasabi | Performance Modifications | 15 | 03-01-2009 10:50 PM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
