Old 11-27-2016, 06:14 PM   #19
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by Pinchlite View Post
I already have this bought.
205/45R16 Comp 2
Wheels:16x7/4x100mm offset 40
Just compare size... I say u should be find
Sent from my HTC One A9 using Tapatalk
Old 11-27-2016, 06:21 PM   #20
Pinchlite
Drives: 2007 yaris HB
lowering
Okay.Going to find some tein 1.5 springs within Canada and order them up.
I will get the springs installed ASAP so once summer arrives I just have to put on the wheels then get an alignment.
Thanks for you're and everyone elses help.
Old 11-27-2016, 06:23 PM   #21
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Have fun post pics after and teins are 1.9 drop but more like 2.o inch.
Old 11-27-2016, 06:34 PM   #22
Pinchlite
springs
1.9???? I thought it was supposed to be 1.5.
Why cant I get a proper answear.
I have spent days reading over many forums.Some say 1.5 not enough,others say 2'' too much.
I have a feeling I will be getting the improper spring height and wont be able to return after installation.
Old 11-27-2016, 06:36 PM   #23
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Tein springs are 1.9 but closer to 2 inch I run a set on my 07 Yaris 2 door
Old 11-27-2016, 06:59 PM   #24
Pinchlite
spring.
Okay.That sounds better.
Here is pic of 1.5 I believe.
Same tire and rim size as mine.
Tanabe DF210 with 16x7 +40offset on 205/45/16 tyres http://i.imgur.com/DSV3drZ.jpg
Can you post pic of your car with wheel and tire specs?
Also exact springs that you bought/have.
Old 11-27-2016, 07:00 PM   #25
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Just do it lol 😁
Old 11-27-2016, 07:04 PM   #26
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
There is mine on teins
Old 11-27-2016, 07:08 PM   #27
tmontague
tmontague's Avatar
Fwiw 1.5" drop is more than noticeable. It made a huge difference in the appearance of my yaris.
Imo lower than that gives you the "wheels tucked in" look which I didn't want as it's not my thing and I wanted function over form. Also the car sits lower with a driver in it than what you'll see when you're standing beside it so take that into account.
The springs will also settle after a few months of driving and will sit slightly lower
Old 11-27-2016, 07:09 PM   #28
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
One more lol
Old 11-27-2016, 07:16 PM   #29
Pinchlite
pics.
Very nice.
Going to bite the bullet and go 1.5 to be on the safe side.Thanks again.
Old 11-27-2016, 07:17 PM   #30
Pinchlite
What wheel and tire size do you have?
Have any side pics.
Old 11-27-2016, 07:17 PM   #31
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Very nice.
Safe side lol
I live in collingwood and we get lots of snow ❄ no issues what so ever. Ride quality is awesome too.
Old 11-27-2016, 07:20 PM   #32
Pinchlite
snow
I know.Midland here.
the other fella said 1.5 is plenty good.
Confused again.
Perhaps i should put the whole idea on the back burner for know.
Way too much uneeded brain racking.
Old 11-27-2016, 07:22 PM   #33
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Confused again.
Lol I say go low or go home if ur in midland than come by park ur car next to mine and see.
Old 11-27-2016, 08:28 PM   #34
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I the other fella said 1.5 is plenty good.
This guy…
Originally Posted by SirDigby View Post
1.5 makes a huge difference in visual appearance.
Don't overthink the half inch. 1.5 or 2 inch. Just do it.
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 11-27-2016, 09:00 PM   #35
tmontague
tmontague's Avatar
Have any side pics.
I'll look for pics but I just put my winters on.
My summer rims are 15x6.5 and +35 offset running 185/60 r15
I have 10mm spacers in the rear. The fit is very flush with no rubbing even when hitting the bump stops on rough Hamilton roads.
Its the exact looks and function I wanted and couldn't be happier.
Old 11-28-2016, 07:10 AM   #36
Rigaud
Drives: 2009 Yaris
Been on a 2" drop since 2014 and on 16x7" 40 offset wheels. Tires 205/45R16.....
I could still lower .5" to 1" more.
Your 1.5" drop is very conservative. Go................Just Do It!!!
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
