Old 12-10-2009, 01:55 AM   #1
paulyd0021
paulyd0021's Avatar
Drives: 2007 Blue Yaris Hatchback
Should I lower the PSI during the Winter?
So I was going to buy some winter tires, but because I cant really afford good ones right now I'm thinking I might hold off, plus I just realized that I would have to pay for mounting and dismounting twice a year which will add up in the long run if i continue to use winter tires. I live in MI.
So my question is if I should lower the PSI in my tires to get better traction?
The car states that the these specific tires (185/60/15) should be at 32 PSI. The max PSI on the tires say 44 PSI. I run them usually around 38 in the front and 37 in the back to get a better MPG. So should I lower them back down to 32 PSI? Or even lower than that? Or is 37 still ok?
I dont feel like I have much control when driving over snow.
Also any other tips? I'm going to try putting a lot of salt bags in my back seat instead of my trunk area since its a FWD. I hear putting it in the very back wont be as good because the front needs more weight. Anyways thanks for any suggestions.
paulyd0021 is offline   Reply With Quote
Old 12-10-2009, 08:46 AM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I am also wondering what I should do for my winter tire pressures. Right now I'm running 35psi in my Firestone Winterforce tires. First storm should be soon, so we'll see how well they behanve.
Old 12-10-2009, 09:08 AM   #3
What is currently on your car for rubber? Are you still on factory originals? If so, as far as winter is concerned, they are shot. Dropping PSI on factory rubber is not going to help one bit. Given your location, you would be best to just suck it up and invest in some winters. Go for what you can afford. Anything snow rated is going to be better than what you currently have. Craigslist may be your friend, but I suspect pickings have probably gotten very slim over the past week.
Old 12-10-2009, 09:58 AM   #4
DerFlosser
DerFlosser's Avatar
I woud recommend slightly higher PSI in the winter. You want a skinnier tire. I run 35lbs and check the pressure every 2 weeks depending on how cold it has been.
DerFlosser is offline   Reply With Quote
Old 12-10-2009, 05:49 PM   #5
paulyd0021
paulyd0021's Avatar
Well I'm not sure if the tires are originals, but I suspect they might not be because the tread is still pretty deep. I tried the old coin trick with a penny and quarter to measure them. I've only had the car since July and I bought it used. Its a 2007 hatchback. The tires that are on it right now are Kelly Navigator Golds 185/60/15. Is there a specific tire that all Yaris's start out with originally?
Old 12-10-2009, 07:09 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
never heard of those tires. the Yaris could come with bridgestone potenza's, yokohamas, or goodyear's from the factory.
Colin Chapman disciple
Old 12-10-2009, 10:12 PM   #7
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
I went to big bear mountain and im running 50 psi on 4 tires
Red Horse is offline   Reply With Quote
New buyer questions...winter... DaveG New YARIS Purchase Forum 45 04-30-2010 01:29 PM
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 04:46 PM
Do you get about 4 MPG less during winter ? paraganek Fuel Economy Forum 24 05-18-2009 09:52 AM
Winter tire width Ironphil Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-21-2009 01:47 AM
Official "CASTREX" WINTER THREAD CASTREX Off-topic / Other Cars / Everything else Discussions 13 10-24-2008 08:19 AM
