Old 01-24-2017, 06:34 PM   #19
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by miiser View Post
But not adapters for wires. Do I need? I thought I can cut the current wires I have to fit them (maybe your speakers need adapters not mine).
So sound I plan to put an amp too?
The Toyota speakers and wires use a different type of connector. So if you don't have the adapters (for lazy people like me), you just cut off the connector ends of the wires that are in the car, and solder on spade connectors. Just make sure to keep the polarity correct.
You can upgrade the head unit or add an amplifier later.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 01-24-2017, 06:40 PM   #20
miiser
miiser's Avatar
Drives: yaris 2009
Ok I am lazy aswell so that's what I am going to do. :p
Hmmm ok then. I will plug my new speakers and then I if I am not pleased with sound I will go straight ahead for the amp.
miiser is offline   Reply With Quote
Old 01-24-2017, 08:35 PM   #21
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
So I found these amps:
Boss audio riot r1004 400watt 2channel (with 100rms for each channel) ~~60euros
Boss audio riot r1002 200watt 2 channel
(With 50rms for each channel). ~~70euros
The speakers I bought have 30rms so both of them are ok for me.
And I found good reviews for both of them.
Ok they are not perfect or the best. I know. But they seem descent to me
In my opinion, you should install the speakers and save the amp money for a head unit next.
On Instagram
On Wheelwell
Old 01-24-2017, 09:30 PM   #22
miiser
miiser's Avatar
Drives: yaris 2009
Thank you for your answers.
I want to ask one more thing. I read somewhere that even if my rear doors have no wiring for speakers, there are ready wires in the panel under the front seat belts, that you can extent them into your door. (They call this waitings in my language) Is that true??
Old 01-25-2017, 11:27 AM   #23
ern-diz
ern-diz's Avatar
This I'm not sure about. I know there are wires in place for certain options even when the car didn't come with the option from the factory, such as wiring for power side mirrors, but I don't remember reading about there being rear door speaker wires in place. That's not to say there isn't, I just don't know for sure.
On Instagram
On Wheelwell
Old 01-25-2017, 11:50 AM   #24
miiser
miiser's Avatar
Drives: yaris 2009
Yaris 2009 5door front speakers replacement.
Ok thank you.
I am also thinking of soundproof my doors because I will remove the panels anyways for the speaker installation.
But I did some research and they are so expensive.
So I am thinking something like a compressed wool sheet of 8mm if I am calling it right.
What do you think about that? Will it make any difference?
Old 01-25-2017, 02:44 PM   #25
ern-diz
ern-diz's Avatar
Ok thank you.
I saw your other post about that. I've only seen dynamat used and know that works well. I saw someone share a link in your other post about it where another forum member padded his Yaris with some type of foam, so check that out. I don't have much experience with it, so I'm sorry I can't be of more help with that piece.
On Instagram
On Wheelwell
Old 01-26-2017, 02:59 PM   #26
miiser
miiser's Avatar
Drives: yaris 2009
Ok thank you again.
Just one more question. What do you think about factory tweeters? I have them in my car. I don't know but in comparison with the speakers they seems very good to me
Old 01-26-2017, 05:19 PM   #27
ern-diz
ern-diz's Avatar
Mine didn't come with them, so I don't have experience with them specifically, but in my general experience, I find that it varies. Some stock speakers (tweeters, mids and subs) are better than others. At the end of the day, if your car came with tweeters, I'd run them until they shredded apart and then replace them lol.
On Instagram
On Wheelwell
Old 01-26-2017, 08:10 PM   #28
miiser
miiser's Avatar
Drives: yaris 2009
Ok you have a point ;)
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
2009 Yaris LB 5-speed MGargano Cars for Sale by private party 9 02-04-2012 02:01 AM
Speakers for 2009 4DR LB AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 5 05-03-2010 12:49 AM
