Old 03-11-2017, 10:10 PM   #1
David C
Drives: White '07 3dr LB
Weak wiper arm spring ?
My right (passenger) side front wiper arm seems to have a lot less spring tension then my left side one, thus resulting in a less then clean swipe. I can also feel the difference in spring tension when lifting both arms up.
Does replacing the spring is a doable thing (can I get a new one ?) or is there any other way to restore the pressure of the wiper arm ?
Old 03-11-2017, 11:29 PM   #2
B.B._07
Drives: 07 5dr
It's more likely that your passenger side wiper is worn rather than the spring. The drivers side wiper arm is much longer so it will feel harder to lift up. The wiper arm spring can't be replaced, you need to replace the wiper arm.
Old 03-11-2017, 11:40 PM   #3
David C
I replaced both wipers in june last year. Drive side is a Bosch Icon and passenger is an Anco 31-13 series. Perhaps the Anco is shot already. I'll install a new one I had as a spare and see if it fix the issue. If it does, then I'll only buy Bosch ones.
Old 03-12-2017, 02:34 PM   #4
tmontague
tmontague's Avatar
The passenger wiper arm is much longer resulting in a longer moment arm for leverage on the spring therefore making the spring feel weak when you lift it off the windshield.
I had the same issue on a 2 month old wiper (usually they last me 6 months at least). I installed new Michelin one's and the issue went away. I'd recommend trying new wipers first before you worry about the spring tension. The tension shouldn't likely ever wear out much as it isn't constantly being compressed and stretched throughout it's life.
Old 03-14-2017, 01:19 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Spray the pivot with some lube. Done.
Changing Rear Wiper Arm barfart UK 6 04-24-2021 11:41 AM
2007 wiper arm tension Pinchlite General Yaris / Vitz Discussion 1 04-16-2016 09:01 PM
Passenger Wiper Arm, lack of tension? TSB? Lil Abner DIY / Maintenance / Service 8 10-24-2010 01:37 PM
How-To: Liftback Rear Wiper Arm - Full Pivot! Chris07LB DIY / Maintenance / Service 5 07-24-2009 03:08 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
