#37 |
![]() Drives: 2008 yaris Join Date: Apr 2017
Could be every 3000 miles like years ago. You Changed plugs when you changed oil. That would be about 30 or so plug replacements in 100,000. G that would be great. Toyota knows, like the SHADOW KNOWS. WHOES the SHADOW, look up.
#38 |
At almost 92k on my `08. Planed on changing the plugs this summer.
How are the factory wires on the yaris? Will they have deteriorated to any consequential degree in 10 years?
- The Black Ship Yaris - |
#39 |
108,400 now, just bought new plus for the first time. Will be changing them out soon.
#40 |
Get some coil boots too.
#41 |
#42 |
Why not, its just a few bucks more.
#43 |
I also like preventive maintenance, however I never thought of changing the boots as I have never seen anyone having problems with these. Luckily for me, they are not normally sold in the stores around so I am not tempted to buy them. :) Plus I believe the original ones, though 13 years old, are still better than new aftermarket ones.
#44 |
![]() ![]() Drives: Hatch Join Date: May 2009
My '07 hatch has been running fine, but I knew it was overdue for a plug change at just under 137000. I bought the stock Denso plugs. It make a big difference in how the car runs.
#45 |
![]() ![]() Drives: Yaris T1 Join Date: Aug 2020
90 000 Kilometers is what is stated in the TIC documents from what I see. Iridiums.
#46 |
$10.25/hr frying chicken
I'm at 160,000 on the original plugs, maybe i should change them?
#47 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
We changed out copper plugs at 30k because they slowly burnt the copper tips away, iridiums melting tempture is so far above the engines combustion tempture you could melt the entire engine down and the irdium tips would still be intact.\ So at 100k you can clean them, regap them and if they dont look damaged reinstall them, Ive heard of people doing 300k km on them and they are mont as long as they are cleaned and gap checked every service. In saying that I run one step colder plugs NGK bkr6eix-11 since I live in the heat and like to give her shit, she runs mint on them. NGK and Denso are both japanese made quality plugs that provide OEM plugs to japanese companies, if Denso is out of a plug they install NGK and vice versa in japanese cars. |
#48 |
#49 |
160,000 miles
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 08:34 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
| Dual ground electrode spark plugs | Kitt | DIY / Maintenance / Service | 15 | 02-09-2009 11:08 AM |
| Spark Plugs | YamilR | DIY / Maintenance / Service | 2 | 09-28-2007 08:38 PM |
