Old 03-04-2018, 10:20 PM   #37
blktiger60
blktiger60's Avatar
Drives: `08 HB S
At almost 92k on my `08. Planed on changing the plugs this summer.
How are the factory wires on the yaris? Will they have deteriorated to any consequential degree in 10 years?
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 05-13-2020, 08:32 PM   #38
blktiger60
blktiger60's Avatar
Drives: `08 HB S
108,400 now, just bought new plus for the first time. Will be changing them out soon.
Old 05-14-2020, 07:25 AM   #39
ex-x-fire
Get some coil boots too.
Old 05-14-2020, 08:23 AM   #40
komichal
Why is that? I have changed spark plugs several times, I have never noticed any damage or worn-out boot.
Old 05-14-2020, 07:28 PM   #41
ex-x-fire
Why not, its just a few bucks more.
Old 05-15-2020, 12:31 AM   #42
komichal
I also like preventive maintenance, however I never thought of changing the boots as I have never seen anyone having problems with these. Luckily for me, they are not normally sold in the stores around so I am not tempted to buy them. :) Plus I believe the original ones, though 13 years old, are still better than new aftermarket ones.
Old 10-21-2020, 01:07 PM   #43
robkay
Drives: Hatch
My '07 hatch has been running fine, but I knew it was overdue for a plug change at just under 137000. I bought the stock Denso plugs. It make a big difference in how the car runs.
robkay is offline   Reply With Quote
Old 10-25-2020, 02:30 PM   #44
Mister
Drives: Yaris T1
90 000 Kilometers is what is stated in the TIC documents from what I see. Iridiums.
Mister is offline   Reply With Quote
Old 01-18-2023, 10:29 AM   #45
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
I'm at 160,000 on the original plugs, maybe i should change them?
mr9865 is offline   Reply With Quote
Old 01-18-2023, 11:53 AM   #46
Compeer
Drives: NCP90 TRD Yaris Manual
Iridium plugs don't melt the tips like copper plugs do, You can clean them check the gap and if they look mint they are mint.
We changed out copper plugs at 30k because they slowly burnt the copper tips away, iridiums melting tempture is so far above the engines combustion tempture you could melt the entire engine down and the irdium tips would still be intact.\
So at 100k you can clean them, regap them and if they dont look damaged reinstall them, Ive heard of people doing 300k km on them and they are mont as long as they are cleaned and gap checked every service.
In saying that I run one step colder plugs NGK bkr6eix-11 since I live in the heat and like to give her shit, she runs mint on them.
NGK and Denso are both japanese made quality plugs that provide OEM plugs to japanese companies, if Denso is out of a plug they install NGK and vice versa in japanese cars.
Compeer is offline   Reply With Quote
Old 01-18-2023, 12:01 PM   #47
sh0rtlife
100-150k is useualy when the OEs start failing in most cars...asuming we are talking miles not kilometers lol
Old 01-18-2023, 02:26 PM   #48
mr9865
mr9865's Avatar
160,000 miles
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 11:08 AM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
