Old 07-17-2017, 07:22 AM   #1
Yaris in France
Drives: 2013 Hatchback
Odd occasional slight clunk
Greetings,
I have a 2013 Yaris (hatchback) ... mileage = 18,000 miles. I've recently noticed a slight clunk (but only occasionally) under some of the following conditions:
1. Downhill (but not necessarily on uphill corners) on tight turns regardless of whether the brakes are engaged or not.
2. Turning into a parking space.
Since I will need to take it to a mechanic here and will be dealing with this in a language I don't speak well, I'd like to have a hint ahead of time as to what might be the problem.
I thought perhaps the car needed to be lubed, but I guess cars this new don't need to be lubed (?)
I should add that I live in a very windy area near the sea with heavy salt air seasonally.
thanks ...
Yaris in France is offline   Reply With Quote
Old 07-17-2017, 08:01 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Full lock steering clunk freeplay? over-center link?
It is disconcerting, and I don't know the mechanism of the hiccup, but my 2007 hatch and some forum commenters have an occasional clunk at full steering lock. (Don't consider this enough of an answer, and please let us know if Toyota or anyone else explains it. Thanks!)
Old 07-18-2017, 06:10 PM   #3
Yaris in France
So, it's possibly just an odd quirky thing and not serious?
Old 07-19-2017, 12:29 AM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I had a similar occasional clunk on my passenger side. It turned out to be a corroded lower control arm bolt. This is a known issue with the front suspension design, however it is unlikely to occur anywhere other than areas subject to heavy winter weather that use lots of road salt. Water can get trapped in the control arm bolt sleeve and corrode the bolt. The fact that you mentioned you live near the sea makes me wonder if perhaps you have driven thru salt water puddles, possibly trapping that water around the LCA bolts. Is there evidence of rust elsewhere underneath the car?
More info about LCA bolts here:
http://www.yarisworld.com/forums/showthread.php?t=27658
My LCA bolt story here:
http://www.yarisworld.com/forums/showthread.php?t=57576
Again this is a long shot but a possibility. Check everything else first as it is likely that it is NOT the LCA bolts but if everything else checks out it might be worth considering.
NYC-SE is online now   Reply With Quote
Old 07-19-2017, 08:10 AM   #5
dogsridewith
Mine did it straight from southern CA, where the roof got sunburned and the undercarriage looks like it never even drove through a puddle. 135k miles. Unknown service history.
(The phenomenon has been discussed briefly somewhere on the forum, but no obvious direct search term(s).)
All steering systems have something somewhere for stops to define full lock. Why do we occasionally hear this one?
Odd throttle issue Suzaku DIY / Maintenance / Service 19 02-03-2022 07:49 PM
Motormount causing front end clunk? cabinfevrr DIY / Maintenance / Service 14 07-06-2015 06:31 PM
'02 Echo Suspension clunk fix tmontague DIY / Maintenance / Service 5 06-29-2015 11:02 AM
Solved: Clunk in Rear Suspension (2008 Yaris 3-door) Redbat01 DIY / Maintenance / Service 2 02-10-2015 12:33 PM
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
