Old 07-03-2015, 03:07 PM   #1
cabinfevrr
Drives: 2008 yaris 5door RS
Motormount causing front end clunk?
Hello, I searched but couldn't find a suitable thread to hijack. If this has been discussed at length, please forgive me and point me where I should look.
I had a front end clunk, so I started looking in to what could be the culprit. It was obvious that the struts were shot, and one coil spring had a crack in it. New struts, coils, and Moog swaybar links. While. I had it apart, I also did the hub bearings, and new hubs while I had the press out. Balljoints and tierods are fine. The knock persists, despite changing parts that were shot anyway. (damhik). So long to short, I was under it today looking at the control arm bolts - no rust, so I coated them with anti-seize and torqued them back on. The rest of the control arm bushings and swaybar bushings seem okay; tights, not cracked, and no play.
2008 5 door hb RS, 143,000kms, original owner. Only other front end parts replaced was drive axles last year, and boots are intact and no noise or play from them.
I'm wondering about the motor mount that is near the rack and pinion. It seems to have a lot of play, and when rocking the car back and forth with just a hand on the tire while trans in park, there is a clunk.
So, please tell me if you think I'm on the right track, and as a guy with the tools but no place to work on it other than a gravel driveway with ramps and Jack stands, would you repair it yourself or let a shop do it?
[IMG][/IMG]
cabinfevrr is offline   Reply With Quote
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 06:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 08:29 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 12:11 AM
For trade, polar white front end Walter California 0 01-08-2007 11:38 PM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
