Old 07-04-2015, 07:28 AM   #7
tmontague
tmontague's Avatar
Fwiw I recently replaced all 3 motor mounts. The two lateral ones are simple and easy to so, both of mine oon my Echo were completely worn out at 345,000km. The middle one located behind the steering rack was in amazing shape and took about 5 hoours to replace w/ a lot of headaches. If the middle one isn't in bad shape then don't touch it. If it is in bad shape then do your self a favor and drop the subframe before swapping it out.
I had a clunk recently but it was under low speed turns. It was the control arm bushing, and it looked to be in great shape.
The only way I was able to diagnose it was to jack up the front end and I hit the wheel w/ a large mallet while putting my hand on different suspension components. The control arms had the most movement/play.
Although your clunk sounds like it's happening under different circumstances.
How are your sway bar bushings and end links?
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 06:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 08:29 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 12:11 AM
For trade, polar white front end Walter California 0 01-08-2007 11:38 PM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
