Old 09-17-2017, 09:04 PM   #145
Stabicraft
Drives: 2008 BLACK YARIS
can you please tell me where to take off a 12 volt feed (when the high beam is activated) for my driving lights relay.
Little or no voltage or current required, just power ONLY when high beam is activated.
Thanking you in advance.
Stabicraft is offline   Reply With Quote
Old 11-15-2017, 11:42 PM   #146
Mister-twister
Drives: 2009 Yaris hatchback
People who can share wire schematic/diagram for master windows switch. Look to hookup original master switch to aftermarket power window kit want use original switch instead of one from kit to have auto option.
Mister-twister is offline   Reply With Quote
Old 11-16-2017, 02:27 AM   #147
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The headlights are earthed to turn on, with permanent 12v power. The simple way is to wire the relay coil across the 2 parallel contacts on the headlight socket.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-17-2018, 08:00 PM   #148
omek07
Hello everyone.
I Have ghe Toyota Yaris Sedan 2007
I am trying to install a wireless back up camera. i found the wires at the back but know i am searching the reverse wire at the panel.
To explain how it works. we have the transmitter and the receiver. Transmitter is at the back and it connects with the reverse light witch i found the wires.
The receiver connects with the Head unit and i have 2 more wires red and black .
I figure that i have to find the reverse wire at the front and to cennect it with the red wire from the receiver. and i hav3 to find ans a ground wire.
can someone tell me if knows where i an find the reverse wire?
omek07 is offline   Reply With Quote
Old 02-06-2021, 09:49 AM   #149
rokus
Drives: yaris
Hi,
I have a 2007 yaris hatchback with no daytime running lights.
I bought an aftermarket LED DRL bar, can anyone tell me how to wire it so it switches on after the car starts?
Thanks
rokus is offline   Reply With Quote
Old 10-18-2022, 04:32 AM   #150
Navigator17
Drives: Toyota Yaris 2011 NCP90
Hi Everyone , i need some help.
I was able to Install a Headunit in my Yaris 2011 - i think i screwed over some wiring connections , so here is what happens now
1 - I insert the key in and move to Accessory level of the key and Headunit powers up - NO AUDIO
2 - No Audio shows even when i move the key to Start position
3 - When i move the Key a little bit beyond the Start position where engine starts to make a bit of funny sound , the Speakers start sounding
4 - Funny thing is all this time Stereo is ON and i can access its screen and buttons so power is coming through
5 -Lastly when i switch off the car and move the Key back to Lock Position , Radio starts to sound and Speak wakes up , ONLY for a while and then Car is off
I must have messed up the Wiring , but i dont know what i did wrong , Please help -
Can you please elaborate what each of these Color wires in my attachment does and which part of it is where its possible gone wrong ?
Navigator17 is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
