![]() Drives: Yaris 1.3 vvt-i Join Date: Jun 2014
Yesterday my Yaris 2007 model started to make clacking noises from the engine. I'm always oversuspicious to new unknown sounds from the car.
Sounds like something is hitting the interior wall clonk, clonk, clonk. It could remind me of the clicking sound you get in a ford fiesta mk I from the taps that hit the valve rods. I fear something is really wrong in the engine. It is worst at low rpm. So my questions is. Anyone driving around with such sounds in their Yaris? Will timing chain make noice before breaking? How about the water/cooling pump? Will the ac unit make such sound before giving up? Any experience you can share in this regard? ps: I have parked the car until I can figure it out
Exhaust manifold heat shield. Mine corroded out recently at the mounting points by the flange and exhibited exactly what you are experiencing.
Your engine is fine, most likely culprit is what wee states. Rip it off when the engine is cool and go about your day.
I've pulled a total of 3 heat shields off of my vibe chasing down rattles, they don't last long in the salt belt
This is the culprit.
![]() Sent from my Elite_5_5_Octa using Tapatalk
@WeeYari Thanks for the suggestion. Will check into that tonight.
Did you just completely removed it?
Sent from my SM-G930W8 using Tapatalk |
I have finally found the culprit. It was a faulty ( new ) oil-filter. Luckily I did not drive the car.
After 8 days in the garage I got a car mechanic to come by and listen to it. Started it and..... dang no disturbing noise. We went outside and talked a bit and then by chance a car drove by with about the same noise but a lot worse. It was the sound of valves breaking down. The mechanic said aha and I had to confirm that I had replaced oil and filter a few days prior to the problem. Check the oil-filter was the advice. I drained the new oil. It was blackish even just after a few km of driving. Then took out the oil filter. The oil in it was clean, just as it is straight from the bottle. Indicating a circulation problem. The mechanic had experienced this once before. Faulty oil-filter resulting in to low oil pressure ( my oil lamp did not indicate any fault ). Anyway, new oil-filter and I'm back on the road. :o) |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
What brand oil filter was you using?
Wow he dodged a serious bullet! My 1980 Subaru hatchback would knock when I put a frame filter on it. I took it off right away. Tried it twice to!
Kudos to your mechanic for asking what was recently done to the car before the problem! And excellent diagnostic procedure!
New oil filter obstructs oil flow engine rattles Toyota Yaris
Well, that's a new one on me. How is it even possible? Something to do with the anti-drainback valve? (Stuck tight somehow?) Some part installed upside down during manufacturing?
(New oil filter obstructs oil flow engine rattles) |
![]() ![]() Drives: '10 Fit Sport MT and 2012 Fit Join Date: Oct 2008
Always need to do a diagnosis near the car instead of relying on people from the internet. There is no way for anyone to know where you specific noise is coming from.
To locate the source of the noise, a stethoscope is used. https://www.familyhandyman.com/tools...cope/view-all/ |
![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
Please tell us what brand. I'm betting it's orange in color.
#13 | |
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg Join Date: Sep 2017
If it wasnt for my modesty ,i would be perfect !
#14 |
It's a wix. Got it form the local shop ( chain shop not a garage ). Have used the same brand for 10 years on various cars, no problems. Anyway got a Lexus/Toyota" genuin part now. I guess I should try to figure out what is wrong with the filter, or if I had managed to put it on wrong ( if that is even possible). But it does not itch that bad.
Regarding the noice. I find it handy to ask on the net. Often I get answers that will lead me in the right direction, but obviously you have to verify. We have salty on my local road during the winter so it could just as well have been a rusty part. ex: the cover on the back break disk has to be replaced as it is nothing but rust. Thanks for all comments and advice. |
#15 |
![]() Drives: Yaris 1.3.vvti Join Date: Sep 2022
This noisei.
This is my yaris 1.3 vvti 2011. Everything is ok, no oil los or something.... https://youtube.com/shorts/AEuS05FfpZk?feature=share |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| 1.0 Aygo Engine: clicking noise - worn valves or bearings? | dj92 | General Yaris / Vitz Discussion | 2 | 06-07-2016 04:54 PM |
| RATTLING NOISE EXHAUST PIPE/BACK OF ENGINE | joeljcruz86 | DIY / Maintenance / Service | 15 | 09-13-2014 07:46 PM |
| Very loud noise from the engine | Stiv | DIY / Maintenance / Service | 27 | 10-27-2009 11:09 AM |
| engine noise?? | poshi | General Yaris / Vitz Discussion | 23 | 09-04-2006 11:45 PM |
