Old 08-21-2018, 11:08 AM   #1
ITA
Drives: 2001 Echo Sedan
Clutch Interchangeability
I just picked up a 2007 Yaris. I noticed that there is some clutch slip (no tach, but I can tell if I get on it, I am not accelerating as much as I should). So, I am looking into replacing the clutch with an Exedy OEM Kit. thebarber stated in this thread, that we can use clutch kits suited for the 1zz and 2zz. They are a bit cheaper than 1nz kits. Can anyone confirm that this is true? Thanks!
ITA is offline   Reply With Quote
Old 08-21-2018, 11:37 AM   #2
ITA
Here are examples for reference:
Yaris Exedy OEM Clutch
Celica GTS Exedy OEM Clutch
According to these two ads, the outer diameter and input shaft spline for each application are identical, yet the Celica application is $50 less.
Old 08-21-2018, 12:04 PM   #3
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
If you scroll down on those ads, it even list the clutch disc and cover part numbers as the same. I wonder if the Throw out and pilot bearing are the same
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 08-21-2018, 12:59 PM   #4
tmontague
tmontague's Avatar
Subscribed. Apparently the 1nz clutch fits with the 2zr meaning a 1zz and 2zz clutch would also work. Gives plenty of options
Old 08-22-2018, 08:34 AM   #5
Blue Vitz has a 2zz clutch in his echo
Old 08-22-2018, 09:03 AM   #6
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
I have a OEM Celica GTS 2ZZ clutch in my echo as well.......works great.
Ronnie V is offline   Reply With Quote
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
