Saint
Drives: 2011 toyota yaris Join Date: Oct 2017
Loose relay in the engine compartment.
Hi everyone.
I have a 2011 yaris hatchback.. I noticed a loose relay inside my engine compartment and was wondering if anyone knew where it is to be fixed. The model number of the relay is MB141967 Hate to see that dangling loose. it was tucked away behind the fuse box but I am sure it is to be bolted somewhere . Sure would appreciate the help Thanks.
A picture of the relay would help.
Sent from my CLT-L04 using Tapatalk |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
A check of the part number showx it to be a general purpose 30 amp relay.
It's most likely been added by a previous owner at some stage. Any non original lights or an aftermarket alarm system?
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Saint
Everything is original. It was tucked away behind the battery, and when i removed the battery to clean some leaves that got in there, I found this. Just wanted to know where it was bolted on to so that I can put it back right there.
Saint
Will try to post one soon.
Saint
[IMG]C:\Users\singulurir\Desktop[/IMG]
Not sure how to post an image from my desktop. HELP !! |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Saint
Here is the picture of the relay.
Saint
Thanks for the directions.
That's definitely not OEM.
Where are the wires going to? That looks like a generic relay to me.
where was it found
Stated in original post. Behind the engine bay fuse box.
Somebody go check their car and see if they can spot one. I'd do it myself but currently don't have access to mine. Sent from my EML-L09 using Tapatalk
![]() ![]() Drives: 2011 Yaris Sedan Join Date: Mar 2017
Sounds like for a mod for me either.
2ZR swap. DO IT! Ask how!
Upgraded horn? Towing lights? DRL bypass? It's aftermarket, no way of knowing what it goes to without tracing the wires. =)
![]() ![]() Drives: 2000 SCP10, 2001 NCP13 Join Date: Jul 2016
Definitely a mod. I found a wire in my car going from the battery to the tail lights, apparently one of the previous owners thought that the indicator circuit wouldn't handle a trailer and decided to use a relay. It does work, though, so I'll just leave it in there for now.
Saint
it just disappears in to the wiring harness. There are no extra lights or any such aftermarket stuff on the car. its pure stock. I bought it from a lady who used it very sparingly. Just felt that maybe someone knew what it was for, and where it would have been mounted on. I found it behind the fuse box in the engine bay.
Have you thought of removing it temporarily to see if something stops working?
| DIY - Exterior lights on when doors are remotely unlocked | CTScott | DIY / Maintenance / Service | 21 | 07-31-2025 06:30 PM |
| For those curious about the 1.0 1KR-FE engine | dj92 | General Yaris / Vitz Discussion | 0 | 09-29-2018 06:33 PM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Something loose in the engine. | Swallow | General Yaris / Vitz Discussion | 39 | 05-27-2009 10:14 PM |
| Q about Routing wires to the engine compartment | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 11-01-2006 07:36 PM |
