Old 10-27-2006, 11:10 AM   #1
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
Q about Routing wires to the engine compartment
What do you guys think is a good way to route a couple of wires from the cockpit to the engine compartment. I would like to hook up my keyless entry to the horn and running lights for visual and audio confirmation. I just wanted to know if there is an easy way to get the wires there before I start drilling unnecessary holes. Thanks in advance!
W.A.S.P is offline   Reply With Quote
Old 10-27-2006, 11:15 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I asked the same question a while back (while in ref to my amp power wire..) and was told to use the ac drip hose; which is located under the passanger dash near the center consol. so I would that a shot.
will work for parts
Old 10-27-2006, 02:19 PM   #3
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
if theyre small wires just try and use the existing main wire grommet behind the steering wheel area.
mikeukrainetz is offline   Reply With Quote
Old 10-27-2006, 07:06 PM   #4
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Thanks guys! I'll try both ways tomorrow morning. I actually need to nmove 6 wires to this area, 4 for the mirror blinkers and 2 for the horn and running lights... any other suggestions?
Old 10-27-2006, 11:04 PM   #5
Kitt
Kitt's Avatar
First of all DO NOT, i repeat, DO NOT drill ANYTHING trough the firewall, just pass the cables trough the main wire grommet, it may be tricky but it works, it is rubber so you can stretch it...
Old 10-28-2006, 12:26 AM   #6
Wayside
Wayside's Avatar
Drives: 07 yaris 5spd sdn
You can grab these wires from inside the car.
Parking Lights green + fuse box, top L, 30 pin plug, pin 29
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
4 for the mirror blinkers .
These should run through the doors right?
Wayside is offline   Reply With Quote
Old 10-28-2006, 02:15 AM   #7
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Thanks! Yes, the blinker wires will go through the doors and the rubber boots, but which would be the best way to go once they are out of the doors? Fuse box? Straight to the front blinkers?
Thanks again for the info!
Old 10-28-2006, 10:16 AM   #8
Wayside
Wayside's Avatar
Try these:
Turn Signal(L) *lt. green *+ *fuse box, top L, 30 pin plug, pin 27
Turn Signal(R) *yellow *+ *fuse box, top L, 30 pin plug, pin 28
Be sure to test all of your wire connections...
As for running the wires through the door, the easiest thing to do is to remove the boot totally and try to anticipate any wires you may need in the future so you only have to do it once.
1. Remove the speaker from the door.
2. Remove the bolt that restricts the door from opening all the way.
3. Unplug the wire harness from the kick.
4. Pop out the plastic plugs that hold the harness in the door.
5. The rubber boot should be free, just pop it out (car side first).
6. Set up all your wires, tape them together and start to snake them through making sure that you follow the route of the wire harness.
7. Last, I like to tape up the wires and make it look as much like a factory job as possible (I use white tape so you know it's not) .
Put it all back together and your done.
One more thing to remember, if your running new speaker wire you can count the factory speaker wires as an extra set of wire for future use.
Hope this was helpful.
Wayside
Old 10-28-2006, 10:52 AM   #9
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Try these:
Attachment 2038
Attachment 2039
Attachment 2036
Attachment 2037
Attachment 2040
Attachment 2041
Attachment 2042
Wayside
Thank you Wayside! I've been through this process before as I installed power windows and locks. It's going to be a little tight now, but I'll manage...My concern now is finding the right wires and not end up frying my fusebox. Well thanks again! I'll take a look at the connections you mentioned.
Old 11-01-2006, 12:24 PM   #10
Lowfront
Drives: Yaris Sedan
I'm pretty sure my buddy drilled the firewall to get my power wire to the amps. I'm afraid to ask why this shouldn't be done.
Lowfront is offline   Reply With Quote
Old 11-01-2006, 07:36 PM   #11
Kitt
Kitt's Avatar
one word: corrosion
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
