![]() Drives: 2007 Toyota Yaris Sedan 1.5 Join Date: Nov 2018
What is the name of this hose?
I can not find the name of this hose for anything and I'm trying to figure out how much it's gonna cost me to order it. Thanks in advance!
20181122_012452.jpg 20181122_012604.jpg |
Check out Rock Auto.
https://www.rockauto.com/en/catalog/...rant+hose,6900 Sent from my EML-L09 using Tapatalk
I noticed that link was for AC refrigerant hoses. Which it appears that is in fact what the hose is. But here is my problem...
I'm leaking engine coolant. After I noticed it and the area dried up a bit I ran the car for a while to get the coolant flowing and the only place I could find any signs of wetness is from this hose where the metal meets the rubber. But if this hose is the AC Compressor to Evap hose, it wouldn't have engine coolant running through it, right?? it's directly at the lowest point of this hose (where liquid would start dripping from it rather than running along it) where I first noticed the puddle of coolant on the plastic under the motor. |
Likely your water pump leaking onto the hose. The only thing around there that will leak coolant is the water pump, or a lower rad hose. If your hose checks out then it is your water pump
![]() Drives: '10 Hatchback Join Date: Dec 2016
Are you sure its coolant, and not oil from the AC compressor? That stuff is sometimes bright green, and the compressor is also above that plastic shield.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| 2001 Echo - CAI Air Box Hose | ITA | Performance Modifications | 0 | 05-25-2017 11:46 AM |
| HVAC dripping water when AC on. Drain hose is NOT clogged. | kustomrtr | DIY / Maintenance / Service | 3 | 09-07-2014 09:45 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| vacuum hose / heater hose size | cali yaris | Performance Modifications | 12 | 05-17-2013 09:58 PM |
