#1 |
vacuum hose / heater hose size
What size is the stock Yaris vacuum and heater hose? I.D.
Thanks
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I know this thread is 2 years old, but I've been needing to know this. I took a pair of calipers and measured the ID of the hose that goes from the valve cover to the intake manifold and it came out to 18.6mm. I found 19mm (3/4") hose online, but I'm not sure if this will work. My hose is leaking and I'd like to get a hose that doesn't have that weird insulated coating around it that I can get a proper hose clamp on instead of that piddly little metal clip.
Ideas? Opinions? This is the hose I was looking at: http://www.amazon.com/gp/product/B00...1&s=automotive As you can see this one is pretty expensive, so I don't want to buy it and it not fit.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#3 |
Has noone replaced this hose with a non-factory part?
#4 |
3/4 hose should work
#5 |
I can't seem to find the thread, but a while back someone asked the same thing and I posted the measurements. Rather than measuring the existing hose, measure the nipple that it will go onto at a point other than the flared area.
#6 |
Yeah I had asked you at one point over on MI I believe, but I never could find that thread either.
#7 |
Thanks Tolmach.
Would silicone be okay to replace that valve cover to intake hose with? I read that silicone isn't safe for oil. I'm not sure how much oil goes through that hose but I know there is some, because it's all over my supercharger throttle body tube thing.
#8 |
It will fail early as oil will soak into it. And a lot of oil blows in to the intake that is why mine is blowing into the air, mmmm the sweet smell of oil.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
Mine is silicon and has been on there for about 3 years so far its held up.
#10 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
My Weapon R intake tube came with a silicone hose and I've had it on for about 9 months with no issues. No softening, no swelling, no discoloration, no deterioration. Now that you mentioned it, I'll keep a close eye on it for any changes and will post them if anything happens.
#11 |
Even though they don't look as nice (I really wanted some pretty blue hoses haha) I went ahead and just got a regular ol black piece of heater tube. It was $5 for 2 feet of it and a couple of steel hose clamps.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Radiator hose size | window_lee | General Yaris / Vitz Discussion | 0 | 03-31-2009 06:33 AM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| Coolant Hose Size Question | vasilios | DIY / Maintenance / Service | 2 | 06-27-2007 09:45 AM |
